Greetings,
I am currently developping my own Grafana Datasource Plugin and while I was checking the best practicies on publishing my plugin as a Datasource one, I saw it is preferable (mandatory ?) to use the graphical components from the Grafana UI library.
I quote this line coming from the best practicies for plugin development ![]()
“When building frontend components, make sure to use Grafana components as the base and follow the Saga Design System.”
Will my datasource really be rejected from being published if I’m using, for example, Carbon Design instead of the Saga Design System ?
