Hi!
I’m developing a plugin for Grafana. I’ve figured out that I should set the variable “scrollable” true in the plugin’s controller, but I use React. How can I make a React plugin scrollable?
Thank you!
Hi!
Thank you!
Use CustomScrollbar component from @grafana/ui
can we do this using css ?
I don’t see why you couldn’t do this.
something like overflow-y: scroll
For a
export const DataList: React.FC = ({ options, data, width, height }) => {
i am returning div with this className but only color is working not scroll
hi Kasmir , see POC below… the content of panel overflows
Hence the override has to be done for class "panel-container "
however this will impact all dashboards
I don’t have your code but I gave it a try and it works for me. I’m using flexboxes so maybe that make a difference
nothing fancy but if it helps
