Make a dashboard public -> localhost in share link
I have a simple question making a dashboard public.
When creating a link to share the ip of the mashine is represented by „ localhost“.
But the otherside could not find the dashboard with localhost in the link.
Do I have miss a setting to be done or did I made something wrong?
check the domain setting in your grafana.ini
perfect!
Thabk you so much.
Problem understood and solved…
:+1:
