Loki's Suitability for Long-Term Log Retention (e.g., 10 Years)
I’m exploring the possibility of using Loki for long-term log retention (e.g., 10 years) for compliance and archival purposes. Is it recommended to use Loki at all for this purpose?
Could Loki introduce native support for long-term storage optimization, such as downsampling, archival features, or efficient handling of large indexes?
Is it possible at all to handle this with storage schema?
If there are existing discussions, documentation, or tools that can help optimize Loki for long-term retention, please share them.
I don’t think there is any inherent problem with using Loki for long-term log storage, as long as you are using backend such as S3. Regarding your questions:
  1. Downsampling does not make sense for logs.
  2. There is no archival feature from Loki, since it offloads the storage part to S3 (or whatever other object storage you use). You can archive S3 (like glacier), but you’d have to manually restore both index and the chunk files from glacier back to S3 before you can query. This is not an ideal use case.
  3. Not sure what you mean by large indexes. Loki keeps one index file per day (after compaction), it won’t get that big even if you have TBs of logs.
In general, as long as you don’t mind paying for the S3 storage, I don’t necessarily see any problem with this. I don’t have this requirement, therefore I haven’t really attempted this. Hopefully someone else has more inputs.
Thanks, Tony, for the feedback.
You’re absolutely right about the index size.
We don’t mind the S3 storage at all (since it’s hardware storage, not in the cloud!), but we’re concerned about querying old data from 2-3 years ago and are unsure how Loki behaves for such queries. As you mentioned, since Loki lacks an archival feature, we need to find an alternative way to move and restore old data to another storage backend, which adds extra effort.
Is there any chance Loki could consider adding an archival feature? We’re looking for a way to handle this within Loki itself instead of relying on additional layers or tools for archiving old data.
If everything is in S3 bucket, querying logs from 3 years ago is no different than querying logs from a day ago. I think your concern would more likely be if you need to query for a month of logs at a time, then you’d need to scale your cluster considerably. Otherwise I don’t think this is of concern.
I am just a regular user like you (if you are a regular user lol). I would recommend you to submit a feature request in GitHub and allow Grafana Loki team the chance to triage.
Hello @tonyswumac, how are you?
I’ll use the same topic so I don’t create a new one unnecessarily.
I want to work with the hot and cold model where I need the hot data for 15 days and 5 years in cold storage due to compliance reasons, both using Azure Storage Account. What do you recommend? I couldn’t find anything in the documentation other than retention.
I was thinking of two possible scenarios:
1 - Azure Storage Account Policy
Single storage account;
Set retention of 5 years in Loki’s compactor;
Configure lifecycle management policy in the Storage Account to move blobs older than 15 days to cool.
2 - Loki Compactor
The other option would be to use some native Loki function, where the compactor would move files older than 15 days to another storage (cool), but I couldn’t find anything.
I am not familiar with Azure blob storage, how does the cold storage behave? Do you have to restore from cold to hot in order to retrieve data?
Loki Compactor does not support moving logs between storage as far as I know. So if you wish to move your Loki data between storage you have to rely on external solutions. The only thing you’d have to be concerned about is when retrieving data from cold storage.
You can read files directly from cold tier without needing to retrieve or move them to hot, the resource itself takes care of this.
I ended up deciding to also use Alloy to send the original logs (JSON) to a separate storage and keep the Loki storage for 30-90 days. If someone needs a log from 2 years ago, they can just download the original file and search for what they need.
Looking for solutions to use S3 Glacier/Deep Archive with Loki. Main challenge: how to identify and restore only specific stream chunks when needed?
Currently seems like I’d need to restore entire time periods blindly, which isn’t practical.
Questions:
  1. Anyone using S3 lifecycle policies with Loki successfully?
  2. Tools for chunk discovery in archived storage?
    The tiering functionality seems incomplete - am I missing something?
    Thanks!
