Loki 2.9.4
This Loki installed in Openshift.
- What are you trying to achieve?
Security issue Unnecessary Http Response Headers found in the Application - How are you trying to achieve it?
Followed this link: How to remove the Server header in NGINX - GetPageSpeed
Tried to add below line doesn’t fix the issue.
server_tokens off;
I used Loki chart to install Loki Openshift, so I can’t install other needed plugins like
nginx-module-security-headers
So can’t use other parameter
What happened?
The way how to fix this security issue by Loki Helm chart install -
