Disable HTTP Server for Loki
Hey Guys,
I have the following question. With Promtail it is possible to disable the HTTP/GRPC server so that it does not expose by default endpoints on the Internet (Configuration | Grafana Loki documentation). After a default Loki installation (docker-compose and loki config attached), Loki exposes on e.g. $IP:3100/metrics log data. Is there currently an option to disable this behavior in Loki itself? Thanks a lot in advance!
docker-compose.yml:
version: "3.8"
services:
  loki:
    image: grafana/loki:2.6.0
    restart: unless-stopped
    command: -config.file=/etc/loki/local-config.yaml
    networks:
      - loki
    ports:
      - 3100:3100
  grafana:
    image: grafana/grafana:latest
    container_name: grafana
    networks:
      - loki
      - web
    labels:
      - "traefik.enable=true"
      - "traefik.http.routers.grafana.entrypoints=websecure"
      - "traefik.http.routers.grafana.rule=Host(`$address`)"
      - "traefik.http.routers.grafana.tls=true"
      - "traefik.http.routers.grafana.tls.certresolver=default"
      - "traefik.http.services.grafana.loadbalancer.server.port=3000"
      - "traefik.docker.network=traefik_web"
networks:
    web:
        external:
    loki:
loki-config.yml (mounted to local-config.yaml in my docker container):
auth_enabled: false
server: (setting "disable: true" has not worked)
  http_listen_port: 3100
  grpc_listen_port: 9096
common:
  path_prefix: /tmp/loki
  storage:
    filesystem:
      chunks_directory: /tmp/loki/chunks
      rules_directory: /tmp/loki/rules
  replication_factor: 1
  ring:
    instance_addr: 127.0.0.1
    kvstore:
      store: inmemory
schema_config:
  configs:
      store: boltdb-shipper
      object_store: filesystem
      schema: v11
      index:
        prefix: index_
        period: 24h
ruler:
  alertmanager_url: http://localhost:9093
analytics:
  reporting_enabled: false
