Hi, we already have loki installed, however it’s running on http.
we tried to edit the loki config to listen to https but we got this error line 4: field https_listen_port not found in type server.Config
And on the explore of grafana/loki ui we set the server to https://localhost:3100 however it’s returning bad gateway error message.
http: server gave HTTP response to HTTPS client
is it possible to run loki to a https? Thanks!
