Hi everyone,
I’m new to Grafana, Loki and Promtail
I need help with the ssl configuration of Loki (v 2.5.0)
Is it possible to set loki so that the api is in https ?
In a practical way how to expose a Loki url such as : https://localhost:3100/loki/api/v1/push
Greetings
Hi everyone,
after a request on the Loki api /config
I could notice the existence of two parameters that can be set in the loki-conif.yaml :
http_tls_config:
cert_file: here your path to the certificate file
key_file: here your path for the key file
It works fine !
Greetings
Where did you find those parameters?
In the documentation I only found one mention of cert_file and key_file in the remote_write section of the ruler.
system
Closed
4
