Hey everyone
We’re running into an issue with our on-prem Loki setup (not on Kubernetes) and wanted to see if anyone else has faced something similar or has ideas on how to fix it.
Our Setup
Cluster: 2-node Loki setup (Ingestor / Distributor / Querier roles)
Promtail: Managed by our DevOps team (runs as a DaemonSet — we don’t have admin access, so a bit of dependency there)
Storage: Everything is on local filesystem mounts:
/data/loki/wal /data/loki/chunks /data/loki/index -
Retention: Configured in
loki-config.yamlfor 5 days- We’ve tuned parameters like chunk block size (2 MB) to optimize space usage
Deletion API: We’ve also tried using the
curldeletion API, but understand it only marks data for deletion in the index — it doesn’t immediately remove chunk files.
What We’re Observing
Chunk file timestamps keep changing
Even old chunk files under/data/loki/chunkskeep getting their “modified date” updated.
When we check with:ls -ltrh /data/loki/chunkswe can see the modification dates changing regularly, even for files that should be past retention.
Retention logic not kicking in
We wrote a small custom cleanup script to delete chunks older than 5 days, but since the modified date keeps updating, nothing ever qualifies for deletion. -
Disk usage keeps going up
Despite retention being set to 5 days (and even after testing the deletion API), the/data/loki/chunksfolder size keeps increasing.
It doesn’t seem like the old data is actually being removed.
Questions
Why would Loki be updating chunk file modification timestamps?
How can we make sure chunks are actually deleted after retention (and not just marked)?
Is there a better approach to enforce retention-based cleanup when running Loki on filesystem storage — not in Kubernetes and not using object storage?
Could something like WAL replay or a background process (e.g. compactor) be touching those files and resetting timestamps?
loki version 2.9.3
loki yaml:
ingester:
lifecycler:
ring:
kvstore:
store: memberlist
replication_factor: 1
final_sleep: 0s
chunk_idle_period: 5m
chunk_retain_period: 30s
max_transfer_retries: 0
chunk_block_size: 2097152
chunk_encoding: snappy
max_chunk_age: 2hdistributor:
ring:
kvstore:
store: memberlistquerier:
engine:
timeout: 1m
query_ingesters_within: 2hquery_range:
align_queries_with_step: true
max_retries: 5
parallelise_shardable_queries: truefrontend:
log_queries_longer_than: 5s
compress_responses: truefrontend_worker:
frontend_address: X.X.X.Xschema_config:
configs:
store: boltdb-shipper
object_store: filesystem
schema: v11
index:
prefix: index_
period: 24hstorage_config:
boltdb_shipper:
active_index_directory: /data/loki/index
cache_location: /data/loki/index_cache
shared_store: filesystemfilesystem:
directory: /data/loki/chunkscompactor:
working_directory: /data/loki/compactor
retention_enabled: true
delete_request_cancel_period: 1m
deletion_mode: filter-and-deletelimits_config:
ingestion_burst_size_mb: 500
ingestion_rate_mb: 1024
ingestion_rate_strategy: global
max_cache_freshness_per_query: 10m
max_global_streams_per_user: 50000
max_query_parallelism: 128
per_stream_rate_limit: 500MB
per_stream_rate_limit_burst: 500MB
reject_old_samples: true
reject_old_samples_max_age: 120h
retention_period: 5d
split_queries_by_interval: 15m
enforce_metric_name: false
max_entries_limit_per_query: 80000
allow_deletes: truechunk_store_config:
max_look_back_period: 0stable_manager:
retention_deletes_enabled: true
retention_period: 5dcurl api:
curl -X DELETE “http://<loki_host>:3100/loki/api/v1/delete”
-H “X-Scope-OrgID: <tenant_id>”
–data-urlencode ‘query={job=“varlogs”} |~ “sensitive_data”’
–data-urlencode ‘start=<start_timestamp>’
–data-urlencode ‘end=<end_timestamp>’If anyone has seen this behavior or has tips on how to manage chunk cleanup and ensure retention works effectively in a non-K8s setup, please share your thoughts.
Thanks in advance!
