Our use case: One account with admin access and second account with read-only access to query logs.
When loki.auth_enabled: true and basicAuth.enabled are set, with a user (e.g., admin) and password configured, logs can be separated using the X-Scope-OrgID header. With the admin account, you can push logs using different X-Scope-OrgID values, and those logs will be isolated accordingly.
However, once we added loki.tenants.{list-of-users} and user/password removed from basicAuth.enabled, the X-Scope-OrgID header is ignored. As a result, regardless of which tenant pushed the logs, they become visible to the user who pushed them, and tenant separation no longer applies.
We pushed logs to two different X-Scope-OrgID values: dc1 and dc2. However, when querying logs from dc1, it shows logs from both dc1 and dc2.
curl -X POST \
-u "${ADMIN_USER}:${ADMIN_PASS}" \
-H "Content-Type: application/json" \
-H "X-Scope-OrgID: dc1" \
"${LOKI_URL}/loki/api/v1/push" \
-d '{
"streams": [
"stream": {
"job": "curl-test",
"instance": "localhost",
"level": "info",
"service": "web-app"
"values": [
["'$(date +%s%N)'", "DC1: User login successful - user_id=12345, ip=192.168.1.100 - DC1"],
["'$(($(date +%s%N) + 1000000))'", "DC1: Database query executed - query_time=45ms, table=users"]
"stream": {
"job": "curl-test",
"level": "error",
"values": [
["'$(($(date +%s%N) + 2000000))'", "ERROR: Failed to connect to payment gateway - timeout after 30s"]
curl -X POST \
-H "X-Scope-OrgID: dc2" \
-d '{
"streams": [
"stream": {
"job": "curl-test",
"level": "info",
"values": [
["'$(date +%s%N)'", "DC2: User login successful - user_id=12345, ip=192.168.1.100 - DC2"],
["'$(($(date +%s%N) + 1000000))'", "DC2: Database query executed - query_time=45ms, table=users"]
"stream": {
"job": "curl-test",
"level": "error",
"values": [
curl -G \
"${LOKI_URL}/loki/api/v1/query_range" \
--data-urlencode 'query={job="curl-test"}' \
--data-urlencode 'start='$(($(date +%s) - 3600)) \
--data-urlencode 'end='$(date +%s) \
--data-urlencode 'limit=100'
{"status":"success","data":{"resultType":"streams","result":[{"stream":{"detected_level":"info","instance":"localhost","job":"curl-test","level":"info","service":"web-app","service_name":"web-app"},"values":[["1755860467526188249","DC2: Database query executed - query_time=45ms, table=users"],["1755860467524190100","DC2: User login successful - user_id=12345, ip=192.168.1.100 - DC2"],["1755860449487778409","DC1: Database query executed - query_time=45ms, table=users"],["1755860449485766180","DC1: User login successful - user_id=12345, ip=192.168.1.100 - DC1"],["1755860026592361995","INFO: Database query executed - query_time=45ms, table=users"],["1755860026590401377","INFO: User login successful - user_id=12345, ip=192.168.1.100-readonly"],["1755860006162838316","INFO: Database query executed - query_time=45ms, table=users"],["1755860006159350985","INFO: User login successful - user_id=12345, ip=192.168.1.100"],["1755858282089758518","INFO: Database query executed - query_time=45ms, table=users"],["1755858282086312820","INFO: User login successful - user_id=12345, ip=192.168.1.100"]]},{"stream":{"detected_level":"error","instance":"localhost","job":"curl-test","level":"error","service":"web-app","service_name":"web-app"},"values":[["1755860467528158039","ERROR: Failed to connect to payment gateway - timeout after 30s"],["1755860449489722964","ERROR: Failed to connect to payment gateway - timeout after 30s"],["1755860026594362093","ERROR: Failed to connect to payment gateway - timeout after 30s"],["1755860006166398737","ERROR: Failed to connect to payment gateway - timeout after 30s"],["1755858282093245841","ERROR: Failed to connect to payment gateway - timeout after 30s"]]}],"stats":{"summary":{"bytesProcessedPerSecond":25445,"linesProcessedPerSecond":361,"totalBytesProcessed":1057,"totalLinesProcessed":15,"execTime":0.04154,"queueTime":0.001987,"subqueries":0,"totalEntriesReturned":15,"splits":5,"shards":5,"totalPostFilterLines":15,"totalStructuredMetadataBytesProcessed":120},"querier":{"store":{"totalChunksRef":0,"totalChunksDownloaded":0,"chunksDownloadTime":0,"queryReferencedStructuredMetadata":false,"chunk":{"headChunkBytes":0,"headChunkLines":0,"decompressedBytes":0,"decompressedLines":0,"compressedBytes":0,"totalDuplicates":0,"postFilterLines":0,"headChunkStructuredMetadataBytes":0,"decompressedStructuredMetadataBytes":0},"chunkRefsFetchTime":7842832,"congestionControlLatency":0,"pipelineWrapperFilteredLines":0}},"ingester":{"totalReached":10,"totalChunksMatched":8,"totalBatches":13,"totalLinesSent":15,"store":{"totalChunksRef":0,"totalChunksDownloaded":0,"chunksDownloadTime":0,"queryReferencedStructuredMetadata":false,"chunk":{"headChunkBytes":1057,"headChunkLines":15,"decompressedBytes":0,"decompressedLines":0,"compressedBytes":0,"totalDuplicates":0,"postFilterLines":15,"headChunkStructuredMetadataBytes":120,"decompressedStructuredMetadataBytes":0},"chunkRefsFetchTime":0,"congestionControlLatency":0,"pipelineWrapperFilteredLines":0}},"cache":{"chunk":{"entriesFound":0,"entriesRequested":0,"entriesStored":0,"bytesReceived":0,"bytesSent":0,"requests":0,"downloadTime":0,"queryLengthServed":0},"index":{"entriesFound":0,"entriesRequested":0,"entriesStored":0,"bytesReceived":0,"bytesSent":0,"requests":0,"downloadTime":0,"queryLengthServed":0},"result":{"entriesFound":0,"entriesRequested":0,"entriesStored":0,"bytesReceived":0,"bytesSent":0,"requests":0,"downloadTime":0,"queryLengthServed":0},"statsResult":{"entriesFound":1,"entriesRequested":1,"entriesStored":1,"bytesReceived":137,"bytesSent":0,"requests":2,"downloadTime":2256913,"queryLengthServed":0},"volumeResult":{"entriesFound":0,"entriesRequested":0,"entriesStored":0,"bytesReceived":0,"bytesSent":0,"requests":0,"downloadTime":0,"queryLengthServed":0},"seriesResult":{"entriesFound":0,"entriesRequested":0,"entriesStored":0,"bytesReceived":0,"bytesSent":0,"requests":0,"downloadTime":0,"queryLengthServed":0},"labelResult":{"entriesFound":0,"entriesRequested":0,"entriesStored":0,"bytesReceived":0,"bytesSent":0,"requests":0,"downloadTime":0,"queryLengthServed":0},"instantMetricResult":{"entriesFound":0,"entriesRequested":0,"entriesStored":0,"bytesReceived":0,"bytesSent":0,"requests":0,"downloadTime":0,"queryLengthServed":0}},"index":{"totalChunks":0,"postFilterChunks":0,"shardsDuration":0,"usedBloomFilters":false}}}}
You expect to see logs based on the X-Scope-OrgID value, not based on which user pushed them.
Additionally, even though we currently have multiple users with the same permissions to push and read logs, users cannot see logs they did not push themselves. We expect to be able to read logs according to the X-Scope-OrgID value, regardless of which user pushed them.
Environment:
Infrastructure: Kubernetes
Deployment tool: helm [loki-6.37.0]
Helm values:
loki:
auth_enabled: true
# Configure multiple tenants/users
tenants:
- name: "loki-admin"
password: "${loki_admin_password}"
- name: "loki-readonly"
password: "${loki_readonly_password}"
gateway:
basicAuth:
enabled: true
htpasswd: |
{{- with $tenants := .Values.loki.tenants }}
{{- range $t := $tenants }}
{{- $username := required "All tenants must have a 'name' set" $t.name }}
{{- if $passwordHash := $t.passwordHash }}
{{- printf "%s:%s\n" $username $passwordHash }}
{{- else if $password := $t.password }}
{{- printf "%s\n" (htpasswd $username $password) }}
{{- else }}
{{- fail "All tenants must have a 'password' or 'passwordHash' set" }}
{{- end }}
{{- end }}
{{- end }}
