Loki not set up properly for alerts and explore
    I’m using Windows 11 and grafana cloud
    I’m trying to search an app for logs connected to a keyword and set up alerts
    I’m using th |= or !~ operators to connect an app search to a string to filter it down
    I’m going to the alerts tab and getting an error message related to loki
  • What happened?
    Errors loading logs in exploer:
    Query error
parse error at line 1, col 3: syntax error: unexpected IDENTIFIER, expecting = or =~ or !~ or !=
Failed to load log volume for this query
parse error at line 1, col 35: syntax error: unexpected IDENTIFIER, expecting = or =~ or !~ or !=
In alerts:
Failed to load the data source configuration for Loki: Unable to fetch alert rules. Is the Loki data source properly configured?
    that there would not be error messages and I could just use grafana
    see above
    I followed the instructions hidden by the question mark at the top right of the explore window
