Errors loading rules Failed to load the data source configuration for Loki: Unable to fetch alert rules. Is the Loki data source properly configured?
i am getting below error in grafana UI
Failed to load the data source configuration for [Loki]
details
 ruler:
      storage:
        type: local
        local:
          directory: /etc/loki/rules
      ring:
        kvstore:
          store: memberlist
      rule_path: /tmp/loki/scratch
      alertmanager_url: http://prom-op-alertmanager.monitoring.svc.cluster.local:9093
      external_url: https://alertmanager.xx
Hi @sachinmane
You’ll need to add the enable_api: true setting for the ruler in order to enable the API, which Grafana uses to load the rules.
thanks for the reply . let me try this and will update you
Any suggestion for the above issue ?
