Loki not saving to s3 but no errors
I have this loki config and full s3 access for the IAM user but the s3 bucket remains empty while there are no errors in the logs,
auth_enabled: false
server:
http_listen_port: 3100
distributor:
ring:
kvstore:
store: memberlist
ingester:
lifecycler:
ring:
kvstore:
store: memberlist
replication_factor: 1
final_sleep: 0s
chunk_idle_period: 5m
chunk_retain_period: 30s
schema_config:
configs:
    store: boltdb-shipper
    object_store: s3
    schema: v11
    index:
    prefix: index_
    period: 24h
storage_config:
boltdb_shipper:
active_index_directory: /loki/index
cache_location: /loki/index_cache
resync_interval: 5s
shared_store: s3
aws:
s3: s3://AKIARE3CZTxcpw4@us-east-1/mydomain.com.docker.loki.logs
s3forcepathstyle: true
limits_config:
enforce_metric_name: false
reject_old_samples: true
reject_old_samples_max_age: 24h
chunk_store_config:
max_look_back_period: 0
table_manager:
chunk_tables_provisioning:
inactive_read_throughput: 0
inactive_write_throughput: 0
provisioned_read_throughput: 0
provisioned_write_throughput: 0
index_tables_provisioning:
retention_deletes_enabled: false
retention_period: 0
