Hi
We are using loki version 2.4.2 .and below is our loki config, we have observed that we are unable to use Log Browser, to search for a specific string.
Now run any other queries, however when we try to search for the string from loki dashabord , it works as expected.
Do we need to tweak any parameter from our side to use log browser as is .
auth_enabled: true
target: all,table-manager
server:
http_listen_port: 3100
grpc_server_max_recv_msg_size: 104857600
grpc_server_max_send_msg_size: 16777216
ingester:
lifecycler:
address: 127.0.0.1
ring:
kvstore:
store: inmemory
replication_factor: 1
final_sleep: 0s
chunk_idle_period: 5m
chunk_retain_period: 30s
max_chunk_age: 1h
chunk_target_size: 1048576
wal:
enabled: true
dir: /var/lib/loki/wal
query_scheduler:
max_outstanding_requests_per_tenant: 2048
query_range:
parallelise_shardable_queries: false
schema_config:
configs:
store: cassandra
object_store: cassandra
schema: v11
index:
prefix: loki_index_
period: 168h
chunks:
prefix: chunk_
period: 168h
storage_config:
cassandra:
auth: true
username: loki_user
password: XXXXXXX
addresses: XXXXXXXXX
keyspace: loki
consistency: LOCAL_ONE
limits_config:
enforce_metric_name: false
reject_old_samples: true
max_query_lookback: 2352h
table_manager:
chunk_tables_provisioning:
inactive_read_throughput: 0
inactive_write_throughput: 0
provisioned_read_throughput: 0
provisioned_write_throughput: 0
index_tables_provisioning:
retention_deletes_enabled: true
retention_period: 2352h
