Slow query on larger logs
I am new with Grafana Loki.
Queries run fine on logs that are only 3-5 lines per record. However, when I send in logs that are 20-30 lines per record, a query could take over a minute and then stopped.
If I do a Live tail, I can see logs coming in. But if I choose last 5m to display them, it takes forever.
What do you suggest that I should optimize in this setup? What value should I change?
Thank you.
How are you deploying Loki? Can you share your configuration? Also have you checked Loki logs for any errors?
This is my config.
   storage_config:
     aws:
       region: us-west-2 # for example, eu-west-2
       bucketnames: xxxxxx # Your actual S3 bucket name, for example, loki-aws-dev-chunks
       s3forcepathstyle: false
   ingester:
       chunk_encoding: snappy
   pattern_ingester:
       enabled: true
   limits_config:
     allow_structured_metadata: true
     volume_enabled: true
     max_query_parallelism: 32
     retention_period: 672h # 28 days retention
   compactor:
     retention_enabled: true
     delete_request_store: s3
   ruler:
    enable_api: true
    storage:
      type: s3
      s3:
        bucketnames: loki-aws-logs-ruler # Your actual S3 bucket name, for example, loki-aws-dev-ruler
      alertmanager_url: http://prom:9093 # The URL of the Alertmanager to send alerts (Prometheus, Mimir, etc.)
   querier:
      max_concurrent: 8
   storage:
      type: s3
      bucketNames:
        chunks: "xxxxxx" # Your actual S3 bucket name (loki-aws-dev-chunks)
        ruler: "xxxxxx" # Your actual S3 bucket name (loki-aws-dev-ruler)
        # admin: "<Insert s3 bucket name>" # Your actual S3 bucket name (loki-aws-dev-admin) - GEL customers only
      s3:
        region: us-west-2 # eu-west-2
        #insecure: false
      # s3forcepathstyle: false
serviceAccount:
 create: true
 annotations:
   "eks.amazonaws.com/role-arn": "arn:aws:iam::XXXXXXXXXX:role/LokiServiceAccountRole" # The service role you created
deploymentMode: Distributed
ingester:
 replicas: 3
 persistence:
   storageClass: gp3
   accessModes:
     - ReadWriteOnce
querier:
 replicas: 3
 maxUnavailable: 2
 persistence:
   storageClass: gp3
   accessModes:
     - ReadWriteOnce
queryFrontend:
 replicas: 2
 maxUnavailable: 1
queryScheduler:
 replicas: 2
distributor:
 replicas: 3
 maxUnavailable: 2
compactor:
 replicas: 1
 persistence:
   storageClass: gp3
   accessModes:
     - ReadWriteOnce
indexGateway:
 replicas: 2
 maxUnavailable: 1
 persistence:
   storageClass: gp3
   accessModes:
     - ReadWriteOnce
ruler:
 replicas: 1
 maxUnavailable: 1
 persistence:
   storageClass: gp3
   accessModes:
     - ReadWriteOnce
Check in your query frontend logs and see if your query are being split. If not, you should consider properly configure query frontend for query splitting. See Query frontend example | Grafana Loki documentation.
