Hello.
query with range 30 days takes about 5 minutes. VM uses only 2-3 Gb of RAM, but 8Gb is available. Is it possible to increase query speed ?
(grafana and loki(with BoltDB) are deployed in docker containers on the same VM)
#logcli query "{project_env=\"PROD\"} |= \"Salesforce query new Opportunity\"" --stats --since=720h
Ingester.TotalReached 32
Ingester.TotalChunksMatched 236
Ingester.TotalBatches 0
Ingester.TotalLinesSent 0
Ingester.HeadChunkBytes 847 kB
Ingester.HeadChunkLines 4344
Ingester.DecompressedBytes 1.4 MB
Ingester.DecompressedLines 4943
Ingester.CompressedBytes 190 kB
Ingester.TotalDuplicates 0
Store.TotalChunksRef 128496
Store.TotalChunksDownloaded 128496
Store.ChunksDownloadTime 4m5.609681266s
Store.HeadChunkBytes 0 B
Store.HeadChunkLines 0
Store.DecompressedBytes 5.9 GB
Store.DecompressedLines 23955333
Store.CompressedBytes 512 MB
Store.TotalDuplicates 0
Summary.BytesProcessedPerSecond 41 MB
Summary.LinesProcessedPerSecond 167820
Summary.TotalBytesProcessed 5.9 GB
Summary.TotalLinesProcessed 23964620
Summary.ExecTime 2m22.798728993s
loki config:
auth_enabled: false
server:
http_listen_port: 3100
http_server_read_timeout: 600s
http_server_write_timeout: 600s
log_level: debug
grpc_server_max_recv_msg_size: 20388078
grpc_server_max_send_msg_size: 20388078
ingester:
lifecycler:
address: 127.0.0.1
ring:
kvstore:
store: inmemory
replication_factor: 1
final_sleep: 0s
wal:
enabled: true
dir: /loki/wal
chunk_idle_period: 1h # Any chunk not receiving new logs in this time will be flushed
max_chunk_age: 1h # All chunks will be flushed when they hit this age, default is 1h
chunk_target_size: 3145728 # Loki will attempt to build chunks up to 1.5MB, flushing first if chunk_idle_period or max_chunk_age is reached first
chunk_retain_period: 20m # Must be greater than index read cache TTL if using an index cache (Default index read cache TTL is 5m)
max_transfer_retries: 0 # Chunk transfers disabled
schema_config:
configs:
store: boltdb-shipper
object_store: filesystem
schema: v11
index:
prefix: index_
period: 24h
chunks:
prefix: chunk_
period: 24h
storage_config:
boltdb_shipper:
active_index_directory: /loki/boltdb-shipper-active
cache_location: /loki/boltdb-shipper-cache
cache_ttl: 720h # Can be increased for faster performance over longer query periods, uses more disk space
shared_store: filesystem
filesystem:
directory: /loki/chunks
compactor:
working_directory: /loki/boltdb-shipper-compactor
retention_enabled: true
limits_config:
enforce_metric_name: false
reject_old_samples: true
max_query_parallelism: 64
max_streams_per_user: 500000
ingestion_rate_mb: 16
ingestion_burst_size_mb: 24
retention_period: 31d
per_stream_rate_limit: 16MB
per_stream_rate_limit_burst: 64MB
max_cache_freshness_per_query: '20m'
ruler:
storage:
type: local
local:
directory: /loki/rules
rule_path: /loki/rules-temp
alertmanager_url: http://localhost:9093
ring:
kvstore:
store: inmemory
enable_api: true
querier:
max_concurrent: 2048
query_timeout: 5m
engine:
timeout: 5m
query_ingesters_within: 1h
query_range:
align_queries_with_step: true
split_queries_by_interval: 1h
max_retries: 2
cache_results: true
parallelise_shardable_queries: true
results_cache:
cache:
enable_fifocache: true
fifocache:
max_size_items: 2048000000
validity: 720h
frontend:
address: 127.0.0.1
log_queries_longer_than: 5s
compress_responses: true
max_outstanding_per_tenant: 2048
query_scheduler:
max_outstanding_requests_per_tenant: 4096
