What Grafana version and what operating system are you using? 9.5.18, openSUSE Leap 15.2
What are you trying to achieve? Get Loki running as a service.
How are you trying to achieve it? By installing Loki, editing the config file, and the service file.
What happened? Starting the service fails with error: “invalid schema config: invalid schema version”.
What did you expect to happen? Running Loki service.
- The Loki configuration file:
auth_enabled: false
server:
http_listen_port: 3100
common:
ring:
instance_addr: 127.0.0.1
kvstore:
store: inmemory
replication_factor: 1
path_prefix: /tmp/loki
schema_config:
configs:
# Old boltdb-shipper schema. Included in example for reference but does not need changing.
index:
period: 24h
prefix: index_
object_store: gcs
schema: v12
store: boltdb-shipper
# New TSDB schema below
index:
period: 24h
prefix: index_
object_store: gcs
schema: v13
store: tsdb
storage_config:
# Old boltdb-shipper configuration. Included in example for reference but does not need changing.
boltdb_shipper:
active_index_directory: /data/index
build_per_tenant_index: true
cache_location: /data/boltdb-cache
# New tsdb-shipper configuration
tsdb_shipper:
active_index_directory: /data/tsdb-index
cache_location: /data/tsdb-cache
query_scheduler:
# the TSDB index dispatches many more, but each individually smaller, requests.
# We increase the pending request queue sizes to compensate.
max_outstanding_requests_per_tenant: 32768
querier:
# Each `querier` component process runs a number of parallel workers to process queries simultaneously.
# You may want to adjust this up or down depending on your resource usage
# (more available cpu and memory can tolerate higher values and vice versa),
# but we find the most success running at around `16` with tsdb
max_concurrent: 16
- The Loki service file:
[Unit]
Description=Loki
After=network.target
[Service]
Type=simple
User=loki
ExecStart=/usr/bin/loki --config.file=/etc/loki/loki.yaml
Restart=always
NoNewPrivileges=true
PrivateTmp=yes
[Install]
WantedBy=multi-user.target
- Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were.
In the journal:
Dec 05 17:57:32 monitoring systemd[1]: Started Loki.
Dec 05 17:57:32 monitoring loki[16982]: level=error ts=2024-12-05T16:57:32.262903362Z >
Dec 05 17:57:32 monitoring systemd[1]: loki.service: Main process exited, code=exited,>
Dec 05 17:57:32 monitoring systemd[1]: loki.service: Failed with result 'exit-code'.
- Did you follow any online instructions? If so, what is the URL? I first tried the local configuration example at Configuration | Grafana Loki documentation, and then the single store TSDB example at Single Store TSDB (tsdb) | Grafana Loki documentation
