I have been wondering about schema_config (especially for S3 but also generally) and I have a few questions.
E.g. the example config on this page
schema_config:
configs:
store: boltdb-shipper
object_store: gcs
schema: v11
index:
prefix: loki_index_
period: 24h
Is the from and schema (the version) something that is versioned upstream for Loki or are these for my own versioning of my specific schema?
If it is the first one, where can I find a list of the schemas?
If it is the second, I assume these need to always be incremented when you make changes?
