I wanted to enable the new tsdb index store. So I created a new schema. Notice that at the time of running this configuration, the from date is in the future.
schema_config:
configs:
store: boltdb
object_store: filesystem
schema: v11
index:
prefix: index_
period: 168h
# - from: "2023-06-20"
# store: tsdb
# object_store: gcs
# schema: v12
# index:
# prefix: index_
# period: 24h # 168h
storage_config:
boltdb:
directory: /index
filesystem:
directory: /chunks
gcs:
bucket_name: monitoring-001-loki
tsdb_shipper:
active_index_directory: /tsdb-index
shared_store: gcs
When I restart Loki with the updated config, Loki fails with the following errors in the logs:
level=info ts=2023-06-16T21:29:44.90262055Z caller=config.go:26 type=config msg=" client_ca_file: \"\""
mkdir : no such file or directory
error initialising module: store
github.com/grafana/dskit/modules.(*Manager).initModule
/drone/src/vendor/github.com/grafana/dskit/modules/modules.go:122
github.com/grafana/dskit/modules.(*Manager).InitModuleServices
/drone/src/vendor/github.com/grafana/dskit/modules/modules.go:92
github.com/grafana/loki/pkg/loki.(*Loki).Run
/drone/src/pkg/loki/loki.go:457
main.main
/drone/src/cmd/loki/main.go:110
runtime.main
/usr/local/go/src/runtime/proc.go:250
runtime.goexit
/usr/local/go/src/runtime/asm_amd64.s:1598
level=info ts=2023-06-16T21:29:44.902626501Z caller=config.go:26 type=config msg=" client_auth_type: \"\""
level=info ts=2023-06-16T21:29:44.902673491Z caller=config.go:26 type=config msg=" key_file: \"\""
level=info ts=2023-06-16T21:29:44.902682208Z caller=config.go:26 type=config msg=" cert_file: \"\""
level=info ts=2023-06-16T21:29:44.902688299Z caller=config.go:26 type=config msg=" grpc_tls_config:"
level=info ts=2023-06-16T21:29:44.902694611Z caller=config.go:26 type=config msg=" client_ca_file: \"\""
level=info ts=2023-06-16T21:29:44.902701113Z caller=config.go:26 type=config msg=" client_auth_type: \"\""
level=info ts=2023-06-16T21:29:44.902707425Z caller=config.go:26 type=config msg=" key_file: \"\""
level=info ts=2023-06-16T21:29:44.902714159Z caller=config.go:26 type=config msg=" cert_file: \"\""
level=info ts=2023-06-16T21:29:44.902723186Z caller=config.go:26 type=config msg=" http_tls_config:"
level=info ts=2023-06-16T21:29:44.9027305Z caller=config.go:26 type=config msg=" tls_min_version: \"\""
level=info ts=2023-06-16T21:29:44.902737292Z caller=config.go:26 type=config msg=" tls_cipher_suites: \"\""
level=info ts=2023-06-16T21:29:44.902743604Z caller=config.go:26 type=config msg=" grpc_listen_conn_limit: 0"
level=info ts=2023-06-16T21:29:44.90275165Z caller=config.go:26 type=config msg=" grpc_listen_port: 9095"
level=info ts=2023-06-16T21:29:44.902758433Z caller=config.go:26 type=config msg=" grpc_listen_address: \"\""
level=info ts=2023-06-16T21:29:44.902765226Z caller=config.go:26 type=config msg=" grpc_listen_network: tcp"
level=info ts=2023-06-16T21:29:44.902772249Z caller=config.go:26 type=config msg=" http_listen_conn_limit: 0"
level=info ts=2023-06-16T21:29:44.902780424Z caller=config.go:26 type=config msg=" http_listen_port: 64310"
level=info ts=2023-06-16T21:29:44.902787148Z caller=config.go:26 type=config msg=" http_listen_address: \"\""
level=info ts=2023-06-16T21:29:44.902794021Z caller=config.go:26 type=config msg=" http_listen_network: tcp"
level=info ts=2023-06-16T21:29:44.902800623Z caller=config.go:26 type=config msg=server:
level=info ts=2023-06-16T21:29:44.902806534Z caller=config.go:26 type=config msg="use_sync_logger: true"
level=info ts=2023-06-16T21:29:44.902813167Z caller=config.go:26 type=config msg="use_buffered_logger: true"
level=info ts=2023-06-16T21:29:44.90281959Z caller=config.go:26 type=config msg="ballast_bytes: 0"
level=info ts=2023-06-16T21:29:44.902827304Z caller=config.go:26 type=config msg="http_prefix: \"\""
level=info ts=2023-06-16T21:29:44.902833546Z caller=config.go:26 type=config msg="target: all"
level=info ts=2023-06-16T21:29:44.905362722Z caller=main.go:108 msg="Starting Loki" version="(version=2.8.2, branch=HEAD, revision=9f809eda7)"
level=info ts=2023-06-16T21:29:44.906510729Z caller=server.go:323 http=[::]:64310 grpc=[::]:9095 msg="server listening on addresses"
level=warn ts=2023-06-16T21:29:44.919514606Z caller=cache.go:114 msg="fifocache config is deprecated. use embedded-cache instead"
level=warn ts=2023-06-16T21:29:44.919563168Z caller=experimental.go:20 msg="experimental feature in use" feature="In-memory (FIFO) cache - chunksembedded-cache"
level=info ts=2023-06-16T21:29:44.923446754Z caller=table_manager.go:134 msg="uploading tables"
level=error ts=2023-06-16T21:29:44.923608753Z caller=log.go:171 msg="error running loki" err="mkdir : no such file or directory\nerror initialising module: store\ngithub.com/grafana/dskit/modules.(*Manager).initModule\n\t/drone/src/vendor/github.com/grafana/dskit/modules/modules.go:122\ngithub.com/grafana/dskit/modules.(*Manager).InitModuleServices\n\t/drone/src/vendor/github.com/grafana/dskit/modules/modules.go:92\ngithub.com/grafana/loki/pkg/loki.(*Loki).Run\n\t/drone/src/pkg/loki/loki.go:457\nmain.main\n\t/drone/src/cmd/loki/main.go:110\nruntime.main\n\t/usr/local/go/src/runtime/proc.go:250\nruntime.goexit\n\t/usr/local/go/src/runtime/asm_amd64.s:1598"
