Loki Fails to Upload Chunks to MinIO Due to Unsupported Characters in Object Name
Setup
I have the following setup running on my development machine:
- Loki
- Alloy
- Grafana
- MinIO
Loki Configuration
Below is the configuration I am using for Loki:
# This is a complete configuration to deploy Loki backed by an S3-compatible API
# like MinIO for storage.
# Index files will be written locally at /loki/index and, eventually, will be shipped to the storage via tsdb-shipper.
auth_enabled: false
server:
http_listen_port: 3100
grpc_listen_port: 9096
log_level: info
grpc_server_max_concurrent_streams: 1000
common:
instance_addr: 127.0.0.1
path_prefix: C:/To_Delete/Loki/loki
replication_factor: 1
ring:
kvstore:
store: inmemory
schema_config:
configs:
store: tsdb
object_store: s3
schema: v13
index:
prefix: index_
period: 24h
storage_config:
tsdb_shipper:
active_index_directory: C:/To_Delete/Loki/loki/index
cache_location: C:/To_Delete/Loki/loki/index_cache
cache_ttl: 1m
aws:
s3: http://<username>:<password>@localhost.:1313/loki
s3forcepathstyle: true
pattern_ingester:
enabled: true
metric_aggregation:
loki_address: localhost:3100
ruler:
alertmanager_url: http://localhost:9093
frontend:
encoding: protobuf
Issue
With this configuration, Loki successfully uploads loki_cluster_seed.json to the loki bucket in MinIO. However, it fails to upload chunks.
Error in Loki Console
level=info ts=2025-04-14T18:39:38.1000413Z caller=flush.go:304 component=ingester msg="flushing stream" user=fake fp=4dd7babe8f8bd469 immediate=false num_chunks=3 total_comp="870 B" avg_comp="290 B" total_uncomp="1.8 kB" avg_uncomp="615 B" full=3 labels="{level=\"INFO\", service_name=\"unknown_service\"}"
level=error ts=2025-04-14T18:39:38.1000413Z caller=flush.go:261 component=ingester loop=9 org_id=fake msg="failed to flush" retries=4 err="failed to flush chunks: store put chunk: XMinioInvalidObjectName: Object name contains unsupported characters.\n\tstatus code: 400, request id: 1836435E55EA2654, host id: 90fa0046e429f497c6ff9f067da5dfc2de025f495215b3d6c189ead5fd156cbf, num_chunks: 3, labels: {level=\"INFO\", service_name=\"unknown_service\"}"
Error in MinIO Audit Logs
"version": "1",
"deploymentid": "52da1725-21cc-4b83-a2c5-07223cd84fd9",
"time": "2025-04-14T18:13:58.6487694Z",
"api": {
"name": "PutObject",
"bucket": "loki",
"object": "fake/4dd7babe8f8bd469/1962e1e0ffb:1962e1e1016:65f2d648",
"status": "Bad Request",
"statusCode": 400
"requestID": "183641F7E777EB78",
"userAgent": "aws-sdk-go/1.55.6 (go1.23.6; windows; amd64)",
"requestPath": "/loki/fake/4dd7babe8f8bd469/1962e1e0ffb:1962e1e1016:65f2d648",
"requestHost": "localhost.:1313",
"accessKey": "minioadmin"
Suspected Cause
The error seems to be caused by the object name containing unsupported characters, specifically the colon (:).
Question
- Is there a way to configure Loki to avoid using colons in object names?
- Alternatively, is there a workaround or fix for this issue?
Any help or guidance would be greatly appreciated!
Thanks in advance!
