At the moment we have one loki with 4-5 promtails feeding logs into that one loki instance. That loki use object storage minio (in loki namespace). We want to separate them, to control retention easier and to save logs in different buckets in s3. I couldn’t find any other solution, before we used retention_stream, but seems that option is no longer available.
old rentention_stream:
# retention_stream:
# - selector: '{namespace="dev"}'
# priority: 1
# period: 24h
# - selector: '{namespace="staging"}'
# priority: 1
# period: 336h
# - selector: '{namespace="prod"}'
# priority: 1
# period: 336h
But now we want to separate dev, staging and prod environments, each in a different loki instance (all loki instances will be on the same cluster). When deploying second loki (in different namespace), backend wont connect to the minio instance with following error:
failed to init delete store: failed to get s3 object: RequestError: send request failed
caused by: Get "http://chunkssys.loki-minio.loki.svc:9000/index/delete_requests/delete_requests.gz": 3 errors occurred:
* dial tcp: lookup chunkssys.loki-minio.loki.svc on 10.43.0.10:53: no such host
Why does it add chunkssys in the s3 url for minio?
This bucket exists in minio, created with the helm deployment (from loki).
minio:
enabled: true
buckets:
- name: chunks
policy: none
purge: false
- name: ruler
policy: none
purge: false
- name: admin
policy: none
purge: false
- name: chunkssys
policy: none
purge: false
- name: rulersys
policy: none
purge: false
- name: adminsys
policy: none
purge: false
Chart version: 5.31.0
Loki version: 2.9.2
Do you have any suggestions how we can achieve that?
