zozoo
June 29, 2024, 3:06pm
1
I am trying to deploy loki3 via helm chart and use an external minio running on a truenas for storage. I have the following configuration:
storage:
# Loki requires a bucket for chunks and the ruler. GEL requires a third bucket for the admin API.
# Please provide these values if you are using object storage.
bucketNames:
chunks: loki-chunks
ruler: loki-ruler
admin: loki-admin
type: s3
s3:
s3: https://s3.zozoo.io:9000
endpoint: https://s3.zozoo.io:9000
region: null
secretAccessKey: <some secret>
accessKeyId: <some access key>
signatureVersion: null
s3ForcePathStyle: true
insecure: false
http_config: {}
# -- Check https://grafana.com/docs/loki/latest/configure/#s3_storage_config for more info on how to provide a backoff_config
backoff_config: {}
I have tested the access of the service with the provided credentials and I was able to read/write/list/delete objects on the buckets but loki is unable to sync the chunks into the minio.
Any suggestion how to fix it?
zozoo
July 1, 2024, 6:58pm
3
Which configuration are we talking about? The above was the storage config of the values.yaml the rest is the default:
the full storage config looks like this:
storage:
bucketNames:
chunks: loki-chunks
ruler: loki-ruler
admin: loki-admin
type: s3
s3:
region: null
secretAccessKey: <some secrets>
accessKeyId: < some access key>
insecure: false
http_config: {}
backoff_config: {}
gcs:
chunkBufferSize: 0
requestTimeout: "0s"
enableHttp2: true
azure:
accountName: null
accountKey: null
connectionString: null
useManagedIdentity: false
useFederatedToken: false
userAssignedId: null
requestTimeout: null
endpointSuffix: null
swift:
auth_version: null
auth_url: null
internal: null
username: null
user_domain_name: null
user_domain_id: null
user_id: null
password: null
domain_id: null
domain_name: null
project_id: null
project_name: null
project_domain_id: null
project_domain_name: null
region_name: null
container_name: null
max_retries: null
connect_timeout: null
request_timeout: null
filesystem:
chunks_directory: /var/loki/chunks
rules_directory: /var/loki/rules
admin_api_directory: /var/loki/admin
zozoo
July 1, 2024, 7:02pm
4
This is the config.yaml the loki has:
auth_enabled: false
chunk_store_config:
chunk_cache_config:
background:
writeback_buffer: 500000
writeback_goroutines: 1
writeback_size_limit: 500MB
default_validity: 0s
memcached:
batch_size: 4
parallelism: 5
memcached_client:
addresses: dnssrvnoa+_memcached-client._tcp.logger-loki-chunks-cache.monitoring.svc
consistent_hash: true
max_idle_conns: 72
timeout: 2000ms
common:
compactor_address: 'http://loki-backend:3100'
path_prefix: /var/loki
replication_factor: 3
storage:
s3:
access_key_id: <access keys>
bucketnames: loki-chunks
insecure: false
s3forcepathstyle: true
secret_access_key: <some secret key>
frontend:
scheduler_address: ""
tail_proxy_url: http://logger-loki-querier.monitoring.svc.cluster.local:3100
frontend_worker:
index_gateway:
mode: simple
limits_config:
max_cache_freshness_per_query: 10m
query_timeout: 300s
reject_old_samples: true
split_queries_by_interval: 15m
volume_enabled: true
memberlist:
join_members:
- loki-memberlist
pattern_ingester:
enabled: false
query_range:
align_queries_with_step: true
cache_results: true
results_cache:
cache:
background:
default_validity: 12h
memcached_client:
addresses: dnssrvnoa+_memcached-client._tcp.logger-loki-results-cache.monitoring.svc
timeout: 500ms
update_interval: 1m
ruler:
storage:
s3:
bucketnames: loki-ruler
insecure: false
type: s3
runtime_config:
file: /etc/loki/runtime-config/runtime-config.yaml
schema_config:
configs:
index:
period: 24h
prefix: index_
object_store: 'filesystem'
schema: v13
store: tsdb
server:
grpc_listen_port: 9095
http_listen_port: 3100
http_server_read_timeout: 600s
http_server_write_timeout: 600s
storage_config:
boltdb_shipper:
index_gateway_client:
server_address: dns+loki-backend-headless.monitoring.svc.cluster.local:9095
hedging:
at: 250ms
max_per_second: 20
up_to: 3
tsdb_shipper:
tracing:
enabled: false
According to your schema_config you are still writing chunks to filesystem.
zozoo
July 1, 2024, 7:23pm
6
Isn’t that how it should be? Written to the filesystem then synced to s3 bucket every minutes or so?
zozoo
July 1, 2024, 7:48pm
7
Nevermind I have changed the testSchemaConfig to use s3 and it’s now loading the data to the s3 bucket. Thank you for pointing out the wrong config.
