Why data not being stored in minio?
We have deployed loki-distributed and we can see that the chunks are being stored in the filesystem at location “/var/loki/wal” but not in the minio bucket.
What’s wrong with our config?
  config: |
    auth_enabled: false
    server:
      http_listen_port: 3100
    common:
      compactor_address: {{ include "loki.compactorFullname" . }}:3100
    distributor:
      ring:
        kvstore:
          store: memberlist
    memberlist:
      join_members:
        - {{ include "loki.fullname" . }}-memberlist
    ingester:
      lifecycler:
        ring:
          kvstore:
            store: memberlist
          replication_factor: 1
      chunk_idle_period: 30m
      chunk_block_size: 262144
      chunk_encoding: snappy
      chunk_retain_period: 1m
      max_transfer_retries: 0
      wal:
        dir: /var/loki/wal
    limits_config:
      enforce_metric_name: false
      reject_old_samples: true
      max_cache_freshness_per_query: 10m
      split_queries_by_interval: 15m
    {{- if .Values.loki.schemaConfig}}
    schema_config:
    {{- toYaml .Values.loki.schemaConfig | nindent 2}}
    {{- end}}
    {{- if .Values.loki.storageConfig}}
    storage_config:
    {{- if .Values.indexGateway.enabled}}
    {{- $indexGatewayClient := dict "server_address" (printf "dns:///%s:9095" (include "loki.indexGatewayFullname" .)) }}
    {{- $_ := set .Values.loki.storageConfig.boltdb_shipper "index_gateway_client" $indexGatewayClient }}
    {{- end}}
    {{- toYaml .Values.loki.storageConfig | nindent 2}}
    {{- if .Values.memcachedIndexQueries.enabled }}
      index_queries_cache_config:
        memcached_client:
          addresses: dnssrv+_memcached-client._tcp.{{ include "loki.memcachedIndexQueriesFullname" . }}.{{ .Release.Namespace }}.svc.{{ .Values.global.clusterDomain }}
          consistent_hash: true
    {{- end}}
    {{- end}}
    runtime_config:
      file: /var/{{ include "loki.name" . }}-runtime/runtime.yaml
    chunk_store_config:
      max_look_back_period: 0s
      {{- if .Values.memcachedChunks.enabled }}
      chunk_cache_config:
        embedded_cache:
          enabled: false
        memcached_client:
          addresses: dnssrv+_memcached-client._tcp.{{ include "loki.memcachedChunksFullname" . }}.{{ .Release.Namespace }}.svc.{{ .Values.global.clusterDomain }}
      {{- end }}
      {{- if .Values.memcachedIndexWrites.enabled }}
      write_dedupe_cache_config:
        memcached_client:
          addresses: dnssrv+_memcached-client._tcp.{{ include "loki.memcachedIndexWritesFullname" . }}.{{ .Release.Namespace }}.svc.{{ .Values.global.clusterDomain }}
      {{- end }}
    table_manager:
      retention_deletes_enabled: false
      retention_period: 0s
    query_range:
      align_queries_with_step: true
      max_retries: 5
      cache_results: true
      results_cache:
        cache:
          {{- if .Values.memcachedFrontend.enabled }}
          memcached_client:
            addresses: dnssrv+_memcached-client._tcp.{{ include "loki.memcachedFrontendFullname" . }}.{{ .Release.Namespace }}.svc.{{ .Values.global.clusterDomain }}
          {{- else }}
          embedded_cache:
            enabled: true
            ttl: 24h
          {{- end }}
    frontend_worker:
      {{- if .Values.queryScheduler.enabled }}
      scheduler_address: {{ include "loki.querySchedulerFullname" . }}:9095
      {{- else }}
      frontend_address: {{ include "loki.queryFrontendFullname" . }}:9095
      {{- end }}
    frontend:
      log_queries_longer_than: 5s
      compress_responses: true
      {{- end }}
      tail_proxy_url: http://{{ include "loki.querierFullname" . }}:3100
    compactor:
      shared_store: s3
    ruler:
      storage:
        type: local
        local:
          directory: /etc/loki/rules
      ring:
        kvstore:
          store: memberlist
      rule_path: /tmp/loki/scratch
      alertmanager_url: https://alertmanager.xx
      external_url: https://alertmanager.xx
# -- Check https://grafana.com/docs/loki/latest/configuration/#schema_config for more info on how to configure schemas
  schemaConfig:
    configs:
      store: boltdb-shipper
      object_store: aws
      schema: v11
      index:
        prefix: loki_index_
        period: 24h
  # -- Check https://grafana.com/docs/loki/latest/configuration/#storage_config for more info on how to configure storages
  storageConfig:
    boltdb_shipper:
      shared_store: s3
      active_index_directory: /var/loki/index
      cache_location: /var/loki/cache
      cache_ttl: 168h
    aws:
      s3: s3://nginx.minio-domain.:80
      bucketnames: <bucketname>
      access_key_id: <accesskey>
      secret_access_key:<key>
      endpoint: nginx.minio-domain.:80
Hi @jennymals you reference port 80 in your MinIO address, but the API is usually on port 9000. If the referenced port doesn’t exist then maybe Loki defaults to saving locally. See if changing the :80 to :9000 makes a difference. I wrote a blog post about this about 6 months ago that you may find helpful How To Deploy Grafana Loki and Save Data to MinIO
Port 80 since we are using nginx ingress in kubernetes. Note that when we use loki-stack we then see data in minio
@matt6d67 could you please send your complete loki-distributed.yaml file using minio i.e. with ingester, distributor, frontend etc separately?
sure, here’s the loki.yaml that I used loki/loki.yaml at main · cniackz/loki · GitHub and we started from loki/loki.yaml at main · grafana/loki · GitHub and adapted that.
for some reason I couldn’t include this in the first response (too many links).
You could run a trace from MinIO using mc, mc admin trace mc admin trace — MinIO Object Storage for Linux to see if traffic is actually reaching MinIO itself, and if it is, what is it trying to do. You could work backwards from the bucket to see where Loki falls over.
@matt6d67 thank you for your support.
