foxrid
April 30, 2025, 12:56pm
1
I am having problem with Alloy, Loki, Prometheus and MiniO.
I can see the logs and data from Prometheus and Loki, but I’m not able to get any data to show up in MinIO. The connection between Loki and MinIO doesn’t seem to be working as expected, even though everything else is functioning correctly. I am using a external MiniO server, does anyone have a good values.yaml for this type of installation? Where I cant get Alloy(k8s-monitoring helm) + loki (grafana/loki helm) + Prometheus (kube-prometheus-stack helm) to connect together and send logs to minio.
loki:
auth_enabled: false
commonConfig:
replication_factor: 1
schemaConfig:
configs:
store: tsdb
object_store: s3
schema: v13
index:
prefix: loki_index_
period: 24h
ingester:
chunk_encoding: snappy
tracing:
enabled: true
pattern_ingester:
enabled: true
limits_config:
allow_structured_metadata: true
volume_enabled: true
ruler:
enable_api: true
querier:
max_concurrent: 4
minio:
enabled: true
storage_config:
aws:
region: ---
bucketnames:
chunks: loki-chunks
ruler: loki-ruler
admin: loki-admin
s3forcepathstyle: true
s3:
endpoint: http://-----:9000
accessKeyId: -----
secretAccessKey: -----
s3ForcePathStyle: true
insecure: true
signatureVersion: v4 # MinIO använder v4 för signering
deploymentMode: SingleBinary
singleBinary:
replicas: 1
resources:
limits:
cpu: 0.5
memory: 1Gi
requests:
cpu: 0.5
memory: 1Gi
extraEnv:
- name: GOMEMLIMIT
value: 750MiB
tolerations:
- key: "node-role.kubernetes.io/control-plane"
operator: "Exists"
effect: "NoSchedule"
chunksCache:
writebackSizeLimit: 10MB
enabled: false
resultsCache:
enabled: false
test:
enabled: false
lokiCanary:
enabled: false
# Zero out replica counts of other deployment modes
backend:
replicas: 0
read:
replicas: 0
write:
replicas: 0
ingester:
replicas: 0
querier:
replicas: 0
queryFrontend:
replicas: 0
queryScheduler:
replicas: 0
distributor:
replicas: 0
compactor:
replicas: 0
indexGateway:
replicas: 0
bloomCompactor:
replicas: 0
bloomGateway:
replicas: 0
I am not getting any errors, the installment seems fine but no data gets sent to my minio server. I only got a “loki_cluster_seed.json” to my bucket “loki-chunks”.
I don’t see anything obviously wrong. Are logs instead stored on Loki’s filesystem?
I’d also try to enable debug log and see if it shows anything, and also check your MinIO logs and see if there is any error there.
The rest of the installation I am running:
helm install prom prometheus-community/kube-prometheus-stack -n prod --set nodeExporter.enabled=false
helm install alloy grafana/k8s-monitoring -n prod --values values-alloy.yaml
helm install loki grafana/loki -n prod --values values-loki.yaml
cluster:
destinations:
clusterMetrics:
enabled: true
nodeMetrics:
enabled: true
clusterEvents:
enabled: true
logs:
enabled: true
kubeStateMetrics:
enabled: true
alloy-metrics:
enabled: true
alloy-singleton:
enabled: true
I am running longhorn, I think they are being stored locally there.
