Hi team,
I need guidance regarding the following issue:
I want to deploy the Grafana+Loki (with S3 compatible storage garage) + Alloy for logs visualization of my 2 application (ui+backend). My setup is a 3VMs k8s cluster hosted on a vcenter with another vm used for garage s3 storage (all in the same network, rechable).
So far I configured garage, and after I managed to deploy Loki, it looks like loki just sends some GET requests to S3 storage but does not ship logs at all. Even tho it looks like I have some logs:
tree
├── compactor
├── tsdb-shipper-active
│ ├── multitenant
│ ├── per_tenant
│ ├── scratch
│ ├── uploader
│ │ └── name
│ └── wal
│ └── s3_2020-05-15
│ └── 1764324052
│ └── 00000000
├── tsdb-shipper-cache
└── wal
├── 00000005
└── checkpoint.000004
└── 00000000
Logs from loki-0 pod:
level=info ts=2025-11-28T10:15:52.37764283Z caller=table_manager.go:136 index-store=tsdb-2020-05-15 msg=“uploading tables”
level=info ts=2025-11-28T10:15:52.450348933Z caller=recalculate_owned_streams.go:49 msg=“starting recalculate owned streams job”
level=info ts=2025-11-28T10:15:52.450381144Z caller=recalculate_owned_streams.go:52 msg=“completed recalculate owned streams job”
level=info ts=2025-11-28T10:16:04.767798089Z caller=memberlist_client.go:552 msg=“initiating cleanup of obsolete entries”
level=info ts=2025-11-28T10:16:22.449813983Z caller=recalculate_owned_streams.go:49 msg=“starting recalculate owned streams job”
level=info ts=2025-11-28T10:16:22.449840425Z caller=recalculate_owned_streams.go:52 msg=“completed recalculate owned streams job”
level=info ts=2025-11-28T10:16:34.768306431Z caller=memberlist_client.go:552 msg=“initiating cleanup of obsolete entries”
level=info ts=2025-11-28T10:16:52.377556072Z caller=table_manager.go:136 index-store=tsdb-2020-05-15 msg=“uploading tables”
level=info ts=2025-11-28T10:16:52.381707604Z caller=table_manager.go:239 index-store=tsdb-2020-05-15 msg=“syncing tables”
level=info ts=2025-11-28T10:16:52.381736433Z caller=table_manager.go:300 index-store=tsdb-2020-05-15 msg=“query readiness setup completed” duration=4.177µs distinct_users_len=0 distinct_users=
level=info ts=2025-11-28T10:16:52.448689797Z caller=checkpoint.go:611 msg=“starting checkpoint”
level=info ts=2025-11-28T10:16:52.449761996Z caller=recalculate_owned_streams.go:49 msg=“starting recalculate owned streams job”
level=info ts=2025-11-28T10:16:52.449786838Z caller=recalculate_owned_streams.go:52 msg=“completed recalculate owned streams job”
level=info ts=2025-11-28T10:16:52.45080956Z caller=checkpoint.go:336 msg=“attempting checkpoint for” dir=/var/loki/wal/checkpoint.000006
level=info ts=2025-11-28T10:16:52.454506983Z caller=checkpoint.go:498 msg=“atomic checkpoint finished” old=/var/loki/wal/checkpoint.000006.tmp new=/var/loki/wal/checkpoint.000006
level=info ts=2025-11-28T10:17:04.767585763Z caller=memberlist_client.go:552 msg=“initiating cleanup of obsolete entries”
level=info ts=2025-11-28T10:17:22.450004695Z caller=recalculate_owned_streams.go:49 msg=“starting recalculate owned streams job”
level=info ts=2025-11-28T10:17:22.450038394Z caller=recalculate_owned_streams.go:52 msg=“completed recalculate owned streams job”
level=info ts=2025-11-28T10:17:34.768060332Z caller=memberlist_client.go:552 msg=“initiating cleanup of obsolete entries”
level=info ts=2025-11-28T10:17:52.376992716Z caller=table_manager.go:136 index-store=tsdb-2020-05-15 msg=“uploading tables”
level=info ts=2025-11-28T10:17:52.449972564Z caller=recalculate_owned_streams.go:49 msg=“starting recalculate owned streams job”
level=info ts=2025-11-28T10:17:52.449992888Z caller=recalculate_owned_streams.go:52 msg=“completed recalculate owned streams job”
level=info ts=2025-11-28T10:18:04.767701235Z caller=memberlist_client.go:552 msg=“initiating cleanup of obsolete entries”
Here is my values.yaml file I used:
loki:
auth_enabled: false
server:
http_listen_port: 3100common:
ring: instance_addr: 127.0.0.1 kvstore: store: inmemory replication_factor: 1 path_prefix: /lokischemaConfig:
configs: - from: 2020-05-15 store: tsdb object_store: s3 schema: v13 index: prefix: loki_index\_ period: 24hstorage_config:
tsdb_shipper: active_index_directory: /var/loki/index cache_location: /var/loki/index_cache aws: s3: http://my_key:my_key_secret@garage_vm_ip:3900/chunksforloki s3forcepathstyle: true region: garage insecure: truestorage:
bucketNames: chunks: chunksforloki \# ruler: rulerforloki \# admin: adminforloki type: s3 s3: endpoint: http://garage_vm_ip:3900 access_key_id: my_key_id secret_access_key: my_key_secret region: garage s3forcepathstyle: true insecure: trueminio:
enabled: false
ruler:
enabled: false
deploymentMode: SingleBinary
singleBinary:
persistence:
enabled: falseextraVolumes:
- name: loki-data persistentVolumeClaim: claimName: loki-pvcextraVolumeMounts:
- name: loki-data mountPath: /var/lokibackend:
replicas: 0
read:
replicas: 0
write:
replicas: 0
ingester:
replicas: 0
querier:
replicas: 0
queryFrontend:
replicas: 0
queryScheduler:
replicas: 0
distributor:
replicas: 0
compactor:
replicas: 0
indexGateway:
replicas: 0
bloomCompactor:
replicas: 0
bloomGateway:
replicas: 0
test:
enabled: false # ← required so you can disable canary
gateway:
enabled: false
lokiCanary:
enabled: false
chunksCache:
enabled: false
resultsCache:
enabled: false
Garage service logs:
nov 28 11:42:32 my-virtual-machine garage[41972]: 2025-11-28T09:42:32.448813Z INFO garage_api_common::generic_server: [::ffff:10.241.13.31]:32435 (key GKb99f25f376d2637a701432de) GET /chunksforloki/loki_cluster_seed.jsonnov 28 11:42:52 my-virtual-machine garage[41972]: 2025-11-28T09:42:52.446459Z INFO garage_api_common::generic_server: [::ffff:10.241.13.31]:51655 (key GKb99f25f376d2637a701432de) GET /chunksforloki?delimiter=&list-type=2&prefix=rules%2Fnov 28 11:43:52 my-virtual-machine garage[41972]: 2025-11-28T09:43:52.446044Z INFO garage_api_common::generic_server: [::ffff:10.241.13.31]:51655 (key GKb99f25f376d2637a701432de) GET /chunksforloki?delimiter=&list-type=2&prefix=rules%2Fnov 28 11:44:52 my-virtual-machine garage[41972]: 2025-11-28T09:44:52.445979Z INFO garage_api_common::generic_server: [::ffff:10.241.13.31]:51655 (key GKb99f25f376d2637a701432de) GET /chunksforloki?delimiter=&list-type=2&prefix=rules%2Fnov 28 11:45:52 my-virtual-machine garage[41972]: 2025-11-28T09:45:52.446152Z INFO garage_api_common::generic_server: [::ffff:10.241.13.31]:51655 (key GKb99f25f376d2637a701432de) GET /chunksforloki?delimiter=&list-type=2&prefix=rules%2Fnov 28 11:46:52 my-virtual-machine garage[41972]: 2025-11-28T09:46:52.446013Z INFO garage_api_common::generic_server: [::ffff:10.241.13.31]:51655 (key GKb99f25f376d2637a701432de) GET /chunksforloki?delimiter=&list-type=2&prefix=rules%2Fnov 28 11:47:52 my-virtual-machine garage[41972]: 2025-11-28T09:47:52.445677Z INFO garage_api_common::generic_server: [::ffff:10.241.13.31]:51655 (key GKb99f25f376d2637a701432de) GET /chunksforloki?delimiter=&list-type=2&prefix=rules%2Fnov 28 11:48:52 my-virtual-machine garage[41972]: 2025-11-28T09:48:52.446543Z INFO garage_api_common::generic_server: [::ffff:10.241.13.31]:51655 (key GKb99f25f376d2637a701432de) GET /chunksforloki?delimiter=&list-type=2&prefix=rules%2Fnov 28 11:49:52 my-virtual-machine garage[41972]: 2025-11-28T09:49:52.446605Z INFO garage_api_common::generic_server: [::ffff:10.241.13.31]:51655 (key GKb99f25f376d2637a701432de) GET /chunksforloki?delimiter=&list-type=2&prefix=rules%2Fnov 28 11:50:52 my-virtual-machine garage[41972]: 2025-11-28T09:50:52.446140Z INFO garage_api_common::generic_server: [::ffff:10.241.13.31]:51655 (key GKb99f25f376d2637a701432de) GET /chunksforloki?delimiter=&list-type=2&prefix=rules%2Fnov 28 11:51:52 my-virtual-machine garage[41972]: 2025-11-28T09:51:52.446439Z INFO garage_api_common::generic_server: [::ffff:10.241.13.31]:51655 (key GKb99f25f376d2637a701432de) GET /chunksforloki?delimiter=&list-type=2&prefix=rules%2Fnov 28 11:51:58 my-virtual-machine garage[41972]: 2025-11-28T09:51:58.617401Z INFO garage_api_common::generic_server: [::ffff:10.241.13.31]:11810 (key GKb99f25f376d2637a701432de) GET /chunksforloki?delimiter=%2F&list-type=2&prefix=index%2Fnov 28 11:52:52 my-virtual-machine garage[41972]: 2025-11-28T09:52:52.446202Z INFO garage_api_common::generic_server: [::ffff:10.241.13.31]:51655 (key GKb99f25f376d2637a701432de) GET /chunksforloki?delimiter=&list-type=2&prefix=rules%2Fnov 28 11:53:52 my-virtual-machine garage[41972]: 2025-11-28T09:53:52.445776Z INFO garage_api_common::generic_server: [::ffff:10.241.13.31]:51655 (key GKb99f25f376d2637a701432de) GET /chunksforloki?delimiter=&list-type=2&prefix=rules%2Fnov 28 11:54:52 my-virtual-machine garage[41972]: 2025-11-28T09:54:52.446243Z INFO garage_api_common::generic_server: [::ffff:10.241.13.31]:51655 (key GKb99f25f376d2637a701432de) GET /chunksforloki?delimiter=&list-type=2&prefix=rules%2Fnov 28 11:55:52 my-virtual-machine garage[41972]: 2025-11-28T09:55:52.446278Z INFO garage_api_common::generic_server: [::ffff:10.241.13.31]:51655 (key GKb99f25f376d2637a701432de) GET /chunksforloki?delimiter=&list-type=2&prefix=rules%2Fnov 28 11:56:52 my-virtual-machine garage[41972]: 2025-11-28T09:56:52.445476Z INFO garage_api_common::generic_server: [::ffff:10.241.13.31]:51655 (key GKb99f25f376d2637a701432de) GET /chunksforloki?delimiter=&list-type=2&prefix=rules%2Fnov 28 11:57:52 my-virtual-machine garage[41972]: 2025-11-28T09:57:52.445448Z INFO garage_api_common::generic_server: [::ffff:10.241.13.31]:51655 (key GKb99f25f376d2637a701432de) GET /chunksforloki?delimiter=&list-type=2&prefix=rules%2Fnov 28 11:58:52 my-virtual-machine garage[41972]: 2025-11-28T09:58:52.446186Z INFO garage_api_common::generic_server: [::ffff:10.241.13.31]:51655 (key GKb99f25f376d2637a701432de) GET /chunksforloki?delimiter=&list-type=2&prefix=rules%2F
Notes:
The PVC is fine.
The bucket exists (I tried with ruler and admin enabled as well and same result)
The s3 key-secret is ok (I tested it using s3cmd)
The GET methods are fine, but there is nothing shipped.
I also tried using chatgpt, here is the values.yaml suggested, with the same result:
loki:
auth_enabled: false
server:
ring: instance_addr: 127.0.0.1 kvstore: store: inmemory replication_factor: 1 path_prefix: /loki# ---------- SCHEMA: TSDB v13 ----------
schemaConfig:
configs: - from: 2020-05-15 store: tsdb object_store: s3 schema: v13 index: prefix: loki_index\_ period: 24h# ---------- TSDB STORAGE CONFIG ----------
storage:
tsdb: dir: /var/loki/tsdb block_ranges_period: 15m # upload frequency: smaller = more often tsdb_shipper: active_index_directory: /var/loki/tsdb-index cache_location: /var/loki/tsdb-cache bucket_store: shared_store: s3 bucketNames: chunks: chunksforloki \# ---------- S3 (Garage) backend ---------- s3: endpoint: http://garage_vm_ip:3900 access_key_id: my_key_id secret_access_key: my_secret region: garage insecure: true s3forcepathstyle: true# Disable MinIO from chart
minio:
enabled: false
# Disable ruler
ruler:
enabled: false
# ----------- DEPLOYMENT MODE (single binary) ----------
singleBinary:
persistence:
replicas: 0
read:
replicas: 0
write:
replicas: 0
ingester:
replicas: 0
querier:
replicas: 0
queryFrontend:
replicas: 0
queryScheduler:
replicas: 0
distributor:
replicas: 0
compactor:
replicas: 0
indexGateway:
replicas: 0
bloomCompactor:
replicas: 0
bloomGateway:
replicas: 0
test:
gateway:
enabled: false
lokiCanary:
enabled: false
chunksCache:
enabled: false
resultsCache:
enabled: false
Can anyone provide some guidance into how can I implement my setup please?
