My loki deployment just stopped returning logs from s3 today.
Here’s the config we’ve been running for month:
affinity: {}
alerting_groups: []
annotations: {}
client: {}
config:
auth_enabled: false
chunk_store_config:
max_look_back_period: 5040h
compactor:
shared_store: filesystem
working_directory: /data/loki/boltdb-shipper-compactor
ingester:
chunk_block_size: 262144
chunk_idle_period: 3m
chunk_retain_period: 1m
lifecycler:
ring:
kvstore:
store: inmemory
replication_factor: 1
max_transfer_retries: 0
wal:
dir: /data/loki/wal
limits_config:
enforce_metric_name: false
reject_old_samples: true
schema_config:
configs:
index:
period: 24h
prefix: index_
object_store: s3
schema: v11
store: boltdb-shipper
server:
http_listen_port: 2355
storage_config:
aws:
s3: s3://XXXXX+XXXXXX@my-region/such-a-cool-s3-bucket
boltdb_shipper:
active_index_directory: /data/loki/boltdb-shipper-active
cache_location: /data/loki/boltdb-shipper-cache
cache_ttl: 24h
filesystem:
directory: /data/loki/chunks
table_manager:
retention_deletes_enabled: true
retention_period: 5040h
env: []
extraArgs: {}
extraContainers: []
extraPorts: []
extraVolumeMounts: []
extraVolumes: []
fullnameOverride: loki-prod-k8s
image:
pullPolicy: IfNotPresent
repository: grafana/loki
tag: 2.4.1
ingress:
annotations: {}
enabled: false
hosts:
- host: chart-example.local
paths: []
tls: []
initContainers: []
livenessProbe:
httpGet:
path: /ready
port: http-metrics
initialDelaySeconds: 45
networkPolicy:
enabled: false
nodeSelector: {}
persistence:
accessModes:
- ReadWriteOnce
annotations: {}
enabled: false
podAnnotations:
prometheus.io/port: http-metrics
prometheus.io/scrape: "true"
podDisruptionBudget: {}
podLabels: {}
podManagementPolicy: OrderedReady
rbac:
create: true
pspEnabled: true
readinessProbe:
httpGet:
path: /ready
port: http-metrics
replicas: 1
resources: {}
securityContext:
fsGroup: 10001
runAsGroup: 10001
runAsNonRoot: true
runAsUser: 10001
service:
annotations: {}
labels: {}
nodePort: null
port: 2355
targetPort: http-metrics
type: ClusterIP
serviceAccount:
annotations: {}
automountServiceAccountToken: true
create: true
serviceMonitor:
additionalLabels: {}
annotations: {}
enabled: false
interval: ""
terminationGracePeriodSeconds: 4800
tolerations: []
tracing:
jaegerAgentHost: null
updateStrategy:
type: RollingUpdate
When I’m running a query, I don’t get any logs past 24hrs, but I can see the logs are being written to s3 and there are no errors in the logs.
Our loki version is: 2.4.1 - but we also tried 2.8.4
This is on k8s and deployed with helm
