hello community,
the last few days I have been working on upgrading our loki to a newer version in our EKS. We keep the the logs in a s3 bucket and I can see the new logs being created there. The logs are still there. Nevertheless when using grafana to see the logs I can not see the logs older that the upgrade time. Any pointers?
This is my values.yaml config:
loki:
auth_enabled: false
structuredConfig:
chunk_store_config:
max_look_back_period: 4320h
table_manager:
retention_deletes_enabled: true
retention_period: 4320h
storage:
type: s3
s3:
region: REGION
s3: s3://REGION/BUCKET
s3ForcePathStyle: true
insecure: true
bucketNames:
chunks: BUCKET
rules: BUCKET
admin: BUCKET
boltdb_shipper:
active_index_directory: /data/loki/index
cache_ttl: 24h
shared_store: s3
cache_location: /data/loki/index_cache
containerSecurityContext:
readOnlyRootFilesystem: false
ingester:
chunk_block_size: 262144
chunk_idle_period: 3m
chunk_retain_period: 1m
lifecycler:
ring:
kvstore:
store: inmemory
replication_factor: 1
max_transfer_retries: 0
schemaConfig:
configs:
store: boltdb-shipper
object_store: s3
schema: v11
index:
prefix: index_
period: 24h
limits_config:
enforce_metric_name: false
reject_old_samples: true
reject_old_samples_max_age: 4320h
serviceAccount:
annotations:
"eks.amazonaws.com/role-arn": "arn:aws:iam::XXXXXXXX:role/loki-role"
singleBinary:
replicas: 1
persistence:
# enabled: false
provisioner:
enabled: false
enterprise:
enabled: false
monitoring:
selfMonitoring:
enabled: false
grafanaAgent:
installOperator: false
lokiCanary:
enabled: false
read:
enabled: false
write:
enabled: false
tableManager:
enabled: false
gateway:
enabled: false
test:
enabled: false
Don’t see anything obvious. Couple of questions:
- What version did you upgrade from and to?
- What changed in configuration?
- Error messages in reader or writer?
Thank you Tony,
- The version upgrade is from version 2.7.0 (helm chart 2.3.0) to version 2.8.3 (helm chart 5.9.2)
- I am trying to match the old version the vest I can the old config will look like this:
auth_enabled: false
chunk_store_config:
compactor:
shared_store: filesystem
working_directory: /data/loki/boltdb-shipper-compactor
ingester:
lifecycler:
ring:
kvstore:
store: inmemory
limits_config:
schema_config:
configs:
index:
period: 24h
prefix: index_
object_store: s3
schema: v11
server:
http_listen_port: 3100
storage_config:
aws:
s3forcepathstyle: true
boltdb_shipper:
cache_ttl: 24h
shared_store: s3
filesystem:
directory: /data/loki/chunks
table_manager:
And the new one:
auth_enabled: false
chunk_store_config:
common:
compactor_address: 'loki'
path_prefix: /var/loki
replication_factor: 3
storage:
s3:
bucketnames: BUCKET
insecure: true
region: REGION
frontend:
scheduler_address: ""
frontend_worker:
index_gateway:
mode: ring
ingester:
lifecycler:
ring:
kvstore:
store: inmemory
limits_config:
max_cache_freshness_per_query: 10m
split_queries_by_interval: 15m
memberlist:
join_members:
- loki-memberlist
query_range:
align_queries_with_step: true
ruler:
storage:
s3:
bucketnames: ruler
insecure: true
region: REGION
type: s3
runtime_config:
file: /etc/loki/runtime-config/runtime-config.yaml
schema_config:
configs:
index:
period: 24h
prefix: index_
object_store: s3
schema: v11
server:
grpc_listen_port: 9095
storage_config:
hedging:
at: 250ms
max_per_second: 20
up_to: 3
table_manager:
- I get this error:
level=error ts=2023-08-01T10:00:20.896343627Z caller=index_set.go:285 table-name=index_19526 msg=“sync failed, retrying it” err=“WebIdentityErr: failed to retrieve credentials\ncaused by: RequestError: send request failed\ncaused by: Post "http://sts.amazonaws.com/\”: dial tcp 209.54.180.124:80: connect: connection refused"
It seems like access issue, but Loki pushes new logs in the same s3.
The error could be because you set insecure to true. I’d try changing your storage configuration a little:
common:
storage:
s3:
bucketnames: BUCKET
region: REGION
Thank you Tony.
It is working with insecure: true.
But for some reason it stated working when I removed the service account annotation for access to the s3 bucket. Loki is using ec2 access to s3 instead.
