Loki datasource on Grafana!
Hi everyone,
I have issue with loki plugin on grafana version 9.4.7:
when i add datasource loki, it get error:
loading chunk 1598 failed. (error: http://grafana-test.com.vn/public/build/lokiplugin.cc1d5d5bb34f38026718.js)
how can i fix that?, please support me
Can you tell me which operating system you are using?
Also, your link is not opening. Could you send me a screenshot of your error and the Loki config file so that I can better understand the problem and provide a better solution?
i think the main reason is the browser, because when i access it via another browser on another computer, grafana-ui still loads lokiplugin
but i cleared the cache but still the same error.
do you know why?
