Loki Canary can't tail new logs
Trying to set up Loki Canary along Loki Canary | Grafana Loki documentation for monitoring our Loki-distributed-stack-performance with Promtail agents.
Loki itself, Canary and Promtail are located in the same cluster.
No matter what I try, I can’t get Canary to compare its ‘own’ logs with those received from Loki due:
Connecting to loki at ws://<query-frontend>.<loki-distributed-namespace>:3100/loki/api/v1/tail?query=%7Bstream%3D%22stdout%22%2Cpod%3D%22loki-canary-jpcrq%22%7D, querying for label 'pod' with value 'loki-canary-jpcrq'
1684995787382100669 ppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppp
1684995788381340178 ppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppp
timeout tailing new logs (timeout period: 10.00s), will retry in 10 seconds: read tcp 10.42.41.143:41824->10.43.222.194:3100: i/o timeout
1684995797382363949 ppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppp
Querying loki for logs with query: http://<query-frontend>.<loki-distributed-namespace>:3100/loki/api/v1/query_range?start=1684982144381336202&end=1684982164381336202&query=%7Bstream%3D%22stdout%22%2Cpod%3D%22loki-canary-jpcrq%22%7D&limit=1000
websocket failed to receive entry 1684995677382905073 within 60.000000 seconds
Canary-config:
extraArgs:
  - '-labelname=pod'
  - '-labelvalue=$(POD_NAME)'
extraEnv:
  - name: HOSTNAME
    valueFrom:
      fieldRef:
        fieldPath: spec.nodeName
  - name: POD_NAME
    valueFrom:
      fieldRef:
        fieldPath: metadata.name
lokiAddress: '<query-frontend>.<loki-distributed-namespace>:3100'
Logs from Query-frontend:
level=info component=frontend org_id=fake latency=fast query="{stream=\"stdout\",pod=\"loki-canary-jpcrq\"}" query_hash=1991069833 query_type=limited range_type=range length=20s start_delta=29.054708262s end_delta=9.054708419s step=1s duration=17.198964ms status=200 limit=1000 returned_lines=0 throughput=0B total_bytes=0B lines_per_second=0 total_lines=0 total_entries=0 store_chunks_download_time=0s queue_time=0s splits=0 shards=16 cache_chunk_req=0 cache_chunk_hit=0 cache_chunk_bytes_stored=0 cache_chunk_bytes_fetched=0 cache_chunk_download_time=0s cache_index_req=32 cache_index_hit=32 cache_index_download_time=65.625898ms cache_result_req=0 cache_result_hit=0 cache_result_download_time=0s
level=debug caller=logging.go:76 traceID=789b20b9476437a6 orgID=fake msg="GET /loki/api/v1/query_range?start=1684997447570202074&end=1684997467570202074&query=%7Bstream%3D%22stdout%22%2Cpod%3D%22loki-canary-jpcrq%22%7D&limit=1000 (200) 17.502083ms"
However, the logs with the pod-label can easily be found in Grafana via the frontend address.
Does anyone have any idea why Canary can’t find the logs via the frontend address?
