Hello everyone, I am new to Grafana, and I am currently trying to set up a PLG stack, but whenever I start everything up and go to explore the Loki data source, all I see are the logs from loki-canary. For example, when I try tailing logs of other pods, the only option I see is loki-canary as seen below:
I am currently running this stack on a rke2 cluster, and I am using the Grafana Helm chart to launch Grafana. I am also running the monolithic Loki helm chart with the following values:
deploymentMode: SingleBinary
loki:
auth_enabled: false
commonConfig:
replication_factor: 1
storage:
type: 'filesystem'
schemaConfig:
configs:
store: tsdb
index:
prefix: loki_index_
period: 24h
object_store: filesystem # we're storing on filesystem so there's no real persistence here.
schema: v13
image:
pullPolicy: Always
singleBinary:
replicas: 1
read:
replicas: 0
backend:
replicas: 0
write:
replicas: 0
global:
dnsService: "rke2-coredns-rke2-coredns"
For Promtail I am using the Daemon set set up like the following:
--- # Daemonset.yaml
apiVersion: apps/v1
kind: DaemonSet
metadata:
spec:
selector:
matchLabels:
template:
metadata:
labels:
spec:
serviceAccount: promtail-serviceaccount
containers:
- name: promtail-container
image: grafana/promtail
args:
- -config.file=/etc/promtail/promtail.yaml
env:
- name: 'HOSTNAME' # needed when using kubernetes_sd_configs
valueFrom:
fieldRef:
fieldPath: 'spec.nodeName'
volumeMounts:
- name: logs
mountPath: /var/log
- name: promtail-config
mountPath: /etc/promtail
- mountPath: /var/lib/docker/containers
readOnly: true
volumes:
- name: logs
hostPath:
path: /var/log
- name: varlibdockercontainers
hostPath:
path: /var/lib/docker/containers
configMap:
--- # configmap.yaml
apiVersion: v1
kind: ConfigMap
metadata:
data:
promtail.yaml: |
server:
http_listen_port: 9080
grpc_listen_port: 0
clients:
- url: http://loki-gateway.default.svc.cluster.local/loki/api/v1/push
positions:
filename: /tmp/positions.yaml
target_config:
sync_period: 10s
scrape_configs:
- job_name: pod-logs
kubernetes_sd_configs:
- role: pod
pipeline_stages:
- docker: {}
relabel_configs:
- source_labels:
- __meta_kubernetes_pod_node_name
target_label: __host__
- action: labelmap
regex: __meta_kubernetes_pod_label_(.+)
- action: replace
replacement: $1
separator: /
source_labels:
- __meta_kubernetes_namespace
- __meta_kubernetes_pod_name
target_label: job
- action: replace
source_labels:
target_label: namespace
- action: replace
source_labels:
target_label: pod
- action: replace
source_labels:
- __meta_kubernetes_pod_container_name
target_label: container
- replacement: /var/log/pods/*$1/*.log
separator: /
source_labels:
- __meta_kubernetes_pod_uid
target_label: __path__
--- # Clusterrole.yaml
apiVersion: rbac.authorization.k8s.io/v1
kind: ClusterRole
metadata:
rules:
- apiGroups: [""]
resources:
- nodes
- services
- pods
verbs:
- get
- watch
- list
--- # ServiceAccount.yaml
apiVersion: v1
kind: ServiceAccount
metadata:
--- # Rolebinding.yaml
kind: ClusterRoleBinding
metadata:
subjects:
- kind: ServiceAccount
namespace: default
roleRef:
kind: ClusterRole
apiGroup: rbac.authorization.k8s.io
To test if logs are getting picked up, I wrote a simple python program that looks like this:
import logging
import sys
from time import sleep
while True:
print("Normal Print Statement")
print("stderr statement", file=sys.stderr)
print("stdout statement", file=sys.stdout)
logging.info("This is an info messages")
logging.warning("This is a warning message")
logging.debug("debugging message")
logging.error("ERROR! ERROR! ERROR! ERROR!")
sleep(10)
I heard that Promtail uses the same discovery methods as Prometheus, so I tried installing Prometheus, and that was able to discover all of the pods.
