Describe the bug
Although the description of the logs matches 11 log files on the server, only 4 of them can be seen in Grafana
To Reproduce
Steps to reproduce the behavior:
- Started Loki
latest from Docker’s hub - Started Promtail
promtail, version 2.4.2 (branch: HEAD, revision: 525040a32) - Query:
{host="lutetia", filename="/var/log/kern.log"} |=
Expected behavior
It should appear in the dropdown of the filename and kern.log label, but it does not appear, although there are logs, including from the current day.
Environment:
- Infrastructure: Docker for Grafana/Loki and Binary for Promtail
- Deployment tool: docker-compose & git clone
Screenshots, Promtail config, or terminal output
If applicable, add any output to help explain your problem.
