Hi Team
It’s good to hear that the new Loki release supports Alert Configuration through alertmanager.
I am working with my team so that Digivalet can deploy grafana-loki-promtail as a centralized logging system. But our team is facing some few challenges. I am not sure whether it’s a bug or our team fault.
Here my scenario is I am running Grafana-loki on 192.168.126.167 and a Promtail client on 192.168.126.168
1> where Portail client is sending my HTTPD logs to loki
2> I have installed alert manager on 192.168.126.167:9093
3> I have defined rule file to trigger alert whenever incoming log per second is more then 5
4> when Loki invoke rule file he gives output as follow
- Feb 09 06:09:06 centos 7.linux vm images.local loki[3394]: level=info ts=2021-02-09T11:09:06.883855921Z caller=metrics.go:83 org_id=1 traceID=5a9b9e046985fa05 latency=fast query=“sum(count_over_time({filename=”/var/log/httpd/access_log"}[1s])) > 5" query_type=metric range_type=instant length=0s step=0s duration=28.679653ms status=200 throughput=0B total_bytes=0B
6> Here range type is instant and I believe that when query type is instant its doesn’t return anything.
7> Help us to find the way to change to query type from instant to range.
Please find below config file of loki,alertmanager,promtail,rules1.yaml
######################### Promtail.yml #####################################################
server:
http_listen_port: 9080
grpc_listen_port: 0
positions:
filename: /tmp/positions.yaml
clients:
- url: http://192.168.126.167:3100/loki/api/v1/push
tenant_id: 1
scrape_configs: - job_name: journal
journal:
max_age: 12h
labels:
job: systemd-journal
relabel_configs:- source_labels: [’__journal__systemd_unit’]
target_label: ‘unit’
- job_name: httpd
entry_parser: raw
static_configs:- targets:
- localhost
labels:
job: httpd
path: /var/log/httpd/*log
pipeline_stages:
- localhost
- match:
selector: ‘{job=“httpd”}’
stages:- regex:
expression: ‘^(?P<remote_addr>[\w.]+) - (?P<remote_user>[^ ]) [(?P<time_local>.)] “(?P[^ ]) (?P[^ ]) (?P[^ ])" (?P[\d]+) (?P<body_bytes_sent>[\d]+) “(?P<http_referer>[^”])” “(?P<http_user_agent>[^”]*)"?’ - labels:
remote_addr:
remote_user:
time_local:
method:
request:
protocol:
status:
body_bytes_sent:
http_referer:
http_user_agent:
- regex:
- targets:
############################### LOKI.YML ###############################################################
auth_enabled: true
server:
http_listen_port: 3100
ingester:
lifecycler:
address: 127.0.0.1
ring:
kvstore:
store: inmemory
replication_factor: 1
final_sleep: 0s
chunk_idle_period: 5m
chunk_retain_period: 30s
max_transfer_retries: 0
schema_config:
configs:
store: boltdb
object_store: filesystem
schema: v11
index:
prefix: index_
period: 168h
ruler:
storage:
type: local
local:
directory: /tmp/loki/rules
rule_path: /tmp/scratch
alertmanager_url: http://192.168.126.167:9093
ring:
kvstore:
store: inmemory
enable_api: true
storage_config:
boltdb:
directory: /tmp/loki/index
filesystem:
directory: /tmp/loki/chunks
limits_config:
enforce_metric_name: false
reject_old_samples: true
chunk_store_config:
max_look_back_period: 0s
table_manager:
retention_deletes_enabled: false
retention_period: 0s
############################ RULES1.YAML #####################################################
groups:
- name: rate-alerting
rules:- alert: HighLogRate
expr: sum(count_over_time({filename="/var/log/httpd/access_log"}[1s])) > 5
for: 1m
labels:
severity: warning
annotations:
title: “High LogRate Alert”
description: “something is logging a lot”
############################ Alertmanager.yml ########################################################
global:
resolve_timeout: 1m
route:
group_by: [‘alertname’]
group_wait: 10s
group_interval: 10s
repeat_interval: 1h
receiver: Slack-Notifications
receivers:
- name: ‘Slack-Notifications’
slack_configs:- api_url: ‘’
channel: ‘#loki-alert-test’
send_resolved: true
- api_url: ‘’
