Loki - Alertmanager issue
Hi Team
It’s good to hear that the new Loki release supports Alert Configuration through alertmanager.
I am working with my team so that Digivalet can deploy grafana-loki-promtail as a centralized logging system. But our team is facing some few challenges. I am not sure whether it’s a bug or our team fault.
Here my scenario is I am running Grafana-loki on 192.168.126.167 and a Promtail client on 192.168.126.168
1> where Portail client is sending my HTTPD logs to loki
2> I have installed alert manager on 192.168.126.167:9093
3> I have defined rule file to trigger alert whenever incoming log per second is more then 5
4> when Loki invoke rule file he gives output as follow
  • Feb 09 06:09:06 centos 7.linux vm images.local loki[3394]: level=info ts=2021-02-09T11:09:06.883855921Z caller=metrics.go:83 org_id=1 traceID=5a9b9e046985fa05 latency=fast query=“sum(count_over_time({filename=”/var/log/httpd/access_log"}[1s])) > 5" query_type=metric range_type=instant length=0s step=0s duration=28.679653ms status=200 throughput=0B total_bytes=0B
    6> Here range type is instant and I believe that when query type is instant its doesn’t return anything.
    7> Help us to find the way to change to query type from instant to range.
    Please find below config file of loki,alertmanager,promtail,rules1.yaml
    ######################### Promtail.yml #####################################################
    server:
    http_listen_port: 9080
    grpc_listen_port: 0
    positions:
    filename: /tmp/positions.yaml
    clients:
  • url: http://192.168.126.167:3100/loki/api/v1/push
    tenant_id: 1
    scrape_configs:
  • job_name: journal
    journal:
    max_age: 12h
    labels:
    job: systemd-journal
    relabel_configs:
    • source_labels: [’__journal__systemd_unit’]
      target_label: ‘unit’
  • job_name: httpd
    entry_parser: raw
    static_configs:
    • targets:
      • localhost
        labels:
        job: httpd
        path: /var/log/httpd/*log
        pipeline_stages:
  • match:
    selector: ‘{job=“httpd”}’
    stages:
    • regex:
      expression: ‘^(?P<remote_addr>[\w.]+) - (?P<remote_user>[^ ]) [(?P<time_local>.)] “(?P[^ ]) (?P[^ ]) (?P[^ ])" (?P[\d]+) (?P<body_bytes_sent>[\d]+) “(?P<http_referer>[^”])” “(?P<http_user_agent>[^”]*)"?’
    • labels:
      remote_addr:
      remote_user:
      time_local:
      method:
      request:
      protocol:
      status:
      body_bytes_sent:
      http_referer:
      http_user_agent:
      ############################### LOKI.YML ###############################################################
      auth_enabled: true
      server:
      http_listen_port: 3100
      ingester:
      lifecycler:
      address: 127.0.0.1
      ring:
      kvstore:
      store: inmemory
      replication_factor: 1
      final_sleep: 0s
      chunk_idle_period: 5m
      chunk_retain_period: 30s
      max_transfer_retries: 0
      schema_config:
      configs:
    store: boltdb
    object_store: filesystem
    schema: v11
    index:
    prefix: index_
    period: 168h
    ruler:
    storage:
    type: local
    local:
    directory: /tmp/loki/rules
    rule_path: /tmp/scratch
    alertmanager_url: http://192.168.126.167:9093
    ring:
    kvstore:
    store: inmemory
    enable_api: true
    storage_config:
    boltdb:
    directory: /tmp/loki/index
    filesystem:
    directory: /tmp/loki/chunks
    limits_config:
    enforce_metric_name: false
    reject_old_samples: true
    chunk_store_config:
    max_look_back_period: 0s
    table_manager:
    retention_deletes_enabled: false
    retention_period: 0s
    ############################ RULES1.YAML #####################################################
    groups:
  • name: rate-alerting
    rules:
    • alert: HighLogRate
      expr: sum(count_over_time({filename="/var/log/httpd/access_log"}[1s])) > 5
      for: 1m
      labels:
      severity: warning
      annotations:
      title: “High LogRate Alert”
      description: “something is logging a lot”
      ############################ Alertmanager.yml ########################################################
      global:
      resolve_timeout: 1m
      route:
      group_by: [‘alertname’]
      group_wait: 10s
      group_interval: 10s
      repeat_interval: 1h
      receiver: Slack-Notifications
      receivers:
  • name: ‘Slack-Notifications’
    slack_configs:
  • api_url: ‘#######’
    channel: ‘#loki-alert-test
    send_resolved: true
