Hi All,
I would like to query the log files based on the output of last one from another logql:
First output:
I would like to run another logql based on the retrieved REQEUSTID “c954754b”, is there any way to save it in a variable?
Thanks.
Hi All,
First output:
Thanks.
I don’t believe this is possible.
Thanks Tony for the reply, we have found an alternative way for this.
What was your alternative solution? I have run into this in the past.
I haven’t tried this, but looks promising: Extract Loki fields into Grafana variables (workaround)
