Extract Loki fields into Grafana variables (workaround)
I recently ran into an issue while trying to use Loki fields as variables on a Grafana dashboard. Specifically, I could only extract Label names or Label values, which wasn’t exactly what I needed.
After some experimentation, I found a workaround that I thought might be useful for others facing a similar issue. The solution involved using the yesoreyeram-infinity-datasource plugin to directly query Loki, and then parsing the necessary fields.
Here’s how I did it:
  1. In the URL Query Params section, I specified a query that would return a single entry for each field value. In my case, the query was:
    count(count_over_time({kind="event", env="live"} | logfmt [1h])) by (view_name)
    This query aggregates logs from a specific view_name over one hour.
  2. The result was a list of values that I could use as variables for my dashboard:
  3. Finally, I was able to parse them using UQL and use these values in my dashboard.
The result was exactly what I needed, and I hope this helps others who might run into the same challenge!
As a grafana enterprise customer, I have raised a ticket to ask for this to become a supported feature. FYI, ticket is [sensitive information]
although you probably can’t see it.
the Enterprise Support people replied with this:
The use of the Infinity plugin is a common one to solve this issue and the plugin itself is developed under Grafana.
However, as requested, I will send this as a feature request to our Voice of Customers team, however, we cannot guarantee anything in terms of implementation or ETA.
