Using A Variable To Filter Loki Results
I have a variable coming from a prometheus datasource.
I would like to use that to filter logs coming from a loki query like this:
{job="containerlogs"} |= $ip_address
When I try that, I receive this error:
syntax error: unexpected NUMBER, expecting STRING or ip
Is there a way to accomplish this?
I figured out the way around this.
After reading this issue, I tried without the All option on the variable.
Then I was able to use this syntax:
{job="containerlogs"} |= ip(`$ip_address`)
