Login to another api and store token
Hello all, what I’m trying to do is to login to prompt the user to login to an external api. Once the user does that, the API will issue them a token. This token can them be use when making subsequent api calls from grafana panels using the infinity datasource plugin. Is it possible to prompt the user in this way and then store the token upon successful login?
Thanks!
it is in the roadmap so currently implemented
Sounds good! Do you know if it’s possible to reference a variable in a header when making an api call using infinity?
should be able to sort it out reading the doc
https://grafana.github.io/grafana-infinity-datasource/docs/authentication
