Log Panel Scroll Not Working
  "commit": "30bb7a93ca",
  "database": "ok",
  "version": "8.3.3"
I have tested both with chrome and microsoft edge , both having same issues
I’m trying to scroll the log panel and it cannot work
Just scroll the log panel back and forth
  • What happened?
Basically I cannot scroll the log panels as shown in the video above
I expect the log panel can be scrolled normally , the table view works fine but when i change to log panel it becomes like this
I use Influxdb and this is my query
import "strings"
from(bucket: "telegraf")
  |> range(start: 0, stop: now())
  |> filter(fn: (r) => r["_measurement"] == "flowfuse_log")
  |> filter(fn: (r) => r["_field"] == "value")
  |> filter(fn: (r) => r["host"] == "${gw}")
  |> filter(fn: (r) => r["path"] == "/var/log/flowfuse-device/flowfuse-device-output.log")
  |> filter(fn: (r) => strings.containsStr(v: r._value, substr: "${level}"))
  |> tail(n: ${amount})
Try to update to the latest stable Grafana version - also check it in the view mode (not in the panel edit mode), because that view mode is the mode, which you are using usually.
Hi yes , I use the grafana latest stable version and the log panel working as expected , thank you
