Hi there!
I’m trying to figure out how to load a default Alloy config via http (import.http?) and apply some variables from a local file on top of that, but I just don’t get how to do it.
Is there maybe a Big Brain out there who can explain? ![]()
Hi there!
You can load a default config and load variables into it. You need to do it by first importing the config, then use custom module to load variables. See Modules | Grafana Alloy documentation and Custom components | Grafana Alloy documentation.
Here is an example.Say you have a default config that has a generic mimir endpoint, and you want to load a custom scrape configuration from an HTTP endpoint into it, you might do something like this (mock config, not tested):
config.alloy:
prometheus.remote_write "_mimir_forwarder" {
endpoint {
url = "<MIMIR_URL>"
basic_auth {
username = "USERNAME"
password = "PASSWORD"
remote.http "my_custom_config" {
path = "<PATH>"
poll_frequency = "10m"
import.string "my_custom_config_import" {
content = remote.http.my_custom_config.content
my_custom_config_import.my_custom_config "this" {
metrics_output = [prometheus.remote_write._mimir_forwarder.receiver]
http config:
declare "my_app" {
argument "metrics_output" {
optional = false
comment = "Where to send collected metrics."
discovery.dns "my_app" {
names = ["<DISCOVERY_RECORD>"]
type = "SRV"
prometheus.scrape "my_app" {
scrape_interval = "10s"
targets = discovery.dns.my_app.targets
forward_to = [prometheus.relabel.my_app.receiver]
prometheus.relabel "my_app" {
forward_to = argument.metrics_output.value
rule {
action = "replace"
replacement = "my_app"
target_label = "app"
It’s pretty neat, but honestly unless you have a very good reason to do this, I’d stick with some sort of configuration management solution instead so you can keep things simple and easy.
