Hi
As I have executed the basic config.alloy to send host data without any exporter, I now wish to migrate my existing Grafana exporter to Alloy. However, I have encountered some issues and need your assistance.
- In my application, I have created a Grafana Agent configuration (
node_exporter.service) with Grafana (v9.3.2) which looks like this:
prometheus:
global:
scrape_interval: 60s
wal_directory: /tmp/grafana-agent-host-wal
server:
http_listen_port: 12348
log_level: error
integrations:
node_exporter:
enabled: true
disable_collectors:
- infiniband
prometheus_remote_write:
- url: https://cortex.x.x.com/api/prom/push
headers:
X-Scope-OrgID: nexxxxxx
According to the reference document, the convert command can convert Prometheus configuration (from Prometheus v2.45) to an Alloy configuration (link: Grafana Alloy CLI Convert).
However, when I try to convert directly from my configuration, it throws an error. But when I change my agent-host.yaml to the following format:
scrape_configs:
- job_name: 'prometheus'
static_configs:
- targets: ['localhost:12348']
remote_write:
headers:
X-Scope-OrgID: nexxxxxxxx
It gets converted into Alloy config successfully.
Could you please assist me in understanding why this issue occurs and how to resolve it without modifying my original configuration?
