Noticed the load test options we defined wasn’t reflected in End of Test report. Are we missing something here
Load Test Options:
export const options = {
scenarios: {
Login: {
executor: ‘per-vu-iterations’,
vus: 3,
iterations: 2,
End of Test:
We used 3 Vus and 2 iterations but summary shows always 1 for both vus and iterations. Console always shows the results of 1 iteration .Do we need set any flag to display all the test iterations output in console. Please clarify
Hi @sattivasudevan !
it’s hard to say why it shows such a summary without looking into the script
In theory, there should be no extra options, and if you use the script like:
import http from 'k6/http';
scenarios: {
Login: {
executor:'per-vu-iterations',
vus: 3,
iterations: 2,
export default function () {
http.get('https://test.k6.io');
It produces the correct output, like:
Could you please provide more details about what’s inside your script?
Cheers!
Hi @olegbespalov ,
Thanks after modifying few options i could see the iterations been executed properly now.
Appreciate your support.
