Per-vu-iterations - send vus from cli
I am trying to use the per-vu-iterations in a scenario where i want all vus to run an exact number of iterations.
export const options = {
scenarios: {
    completeconfirm: {
        executor: 'per-vu-iterations',
        maxDuration: '30m',
qn 1: is it possible to send in value of vus and iterations from cli for this scenario ?
k6 run -i 10 -u 2 /test.js
qn 2: is this a typo here for the cli options - mentioning number of vus?
docs has -v instead of -u
Hi @jeevananthank
  1. There is no cli option but you can use -e to set an enveronment variable and use that
    k6 run -e vus=20 script.js
scenarios: {
    completeconfirm: {
        maxDuration: '30m',
        vus: parseInt(__ENV.vus),
I highly recommend if you do this to add some logic for checking if this is set and so on :wink: Also vus is probably not a great name it should probably be a bit more descriptive
  1. it’s a typo
