Single Iteration only for 100 users not working as expected
Hi all!
I want to perform a test where 100 VU will perform only one iteration each.
I couldn’t manage to achieve it using the following configurations:
1.
export const options = { vus: 100, duration: ‘30s’ }
results:
iterations…: 582 16.601238/s
vus…: 1 min=1 max=100
2
export const options = { vus: 100, iterations: 100 }
results:
iterations…: 100 17.248174/s
vus…: 17 min=17 max=94
3
scenarios: {
fixed_100_users: {
executor: ‘per-vu-iterations’,
vus: 100,
iterations: 1,
maxDuration: ‘30s’,
results:
iterations…: 100 16.460846/s
vus…: 3 min=3 max=98
4
scenarios: {
fixed_100_users: {
executor: ‘shared-iterations’,
vus: 100,
iterations: 100,
maxDuration: ‘30s’,
results:
iterations…: 100 16.569275/s
vus…: 1 min=1 max=95
Any ideas please?
Thank you!
Hi @pantelisvardakas !
Welcome to the community forums! :wave:
Can I clarify a bit? When you say:
Do you mean you want to give some endpoint an instant load of 100 users? And what are your concerns if the same k6 virtual user performs the iteration?
Thanks!
@olegbespalov i think i found the solution.
The tests working as expected but I misunderstood the results. After checking the documentation i clarified that vus is of type Gauge and displayed the current value not the total.
If you check my post you will see that the results are displaying a different value than the one I expected. But again was my misunderstanding!
Anyway thank you for your question!
No worries, I’m glad that it’s sorted!
