Lines not connected when lack of data
Hi, I am using influxdb as a backend and have 2 charts that are not showing correctly.
In one case I only get a value of 1 infrequently, while I would like the default to still show as zero. However the chart shows “no data” for the period selected if there hasn’t been data.
The other scenario is I have a temperature that is only populated into the database when it changes, in my case I get “no data” or gaps in the graph for the period where the temperature stayed the same.
Here are the queries:
1)
SELECT count(“value”) FROM “binary_sensor.front_door_contact” WHERE time >= now() - 6h GROUP BY time(15s) fill(0)
2)
SELECT moving_average(mean(“value”), 20) FROM “°C” WHERE (“entity_id” = ‘presence_sensor_temperature_measurement’) AND time >= now() - 6h GROUP BY time(15s) fill(previous)
As you can see, I have set the “fill(previous)” on the second query, but it can still show gaps.
Here are the graphs
1)
2)
You have on the config for your panel the possibility to set a default value when you have no_data or null.
Hope it helps.
Good Luck
Hi, thanks for the info. I am not sure where to find that.
Good Luck
I don’t seem to have those options for some reason
please install the latest version
