Lines being drawn between unadjacent points in graphs
    AWS Managed Grafana, v8.2.5
    I would like to use the time series panel feature to connect data points with lines.
    By using the setting under “Graph Styles”.
  • What happened?
    There appear to be some issues where extra lines are drawn between data points that are not adjacent to each-other. Attached you can find a graph with the “Lines” option enabled and disabled:
    I expected there not to be these extra lines
    Relevant Panel JSON model:
  "fieldConfig": {
    "defaults": {
      "custom": {
        "drawStyle": "line",
        "lineInterpolation": "smooth",
        "barAlignment": 0,
        "lineWidth": 1,
        "fillOpacity": 3,
        "gradientMode": "none",
        "spanNulls": false,
        "showPoints": "always",
        "pointSize": 3,
        "stacking": {
          "mode": "none",
          "group": "A"
        "axisPlacement": "left",
        "axisLabel": "",
        "scaleDistribution": {
          "type": "linear"
        "hideFrom": {
          "tooltip": false,
          "viz": false,
          "legend": false
        "thresholdsStyle": {
          "mode": "off"
        "lineStyle": {
          "fill": "solid"
        "axisGridShow": true
      "color": {
        "mode": "palette-classic"
      "thresholds": {
        "mode": "absolute",
        "steps": [
            "value": null,
            "color": "green"
            "value": 80,
            "color": "red"
      "mappings": [],
      "max": 10
    No errors in the Grafana UI
    No
Solved:
The order in which points are connected by lines depends on the ordering of the points in the table returned by the query. Adding an “ORDER BY time” to my query solved this.
Thank you to agnestoulet1 from this thread
