Is there a page going through the limitation using k6 operator?
thanks
Welcome to the community…
Can you please explain a bit more? What type of limitations are we talking about? Did you encounter any issue / limitations ? If yes what is the use case?
I am using K6 Operator for quite some time on 4-5 clusters and K6 test scripts are scheduled to run every 3 minutes on those clusters via operator. I did not encountered any issue so far…
Thanks in advance
Suleyman Kutlu
