Unexpected request rate and iterations using k6 operator
My CRD contains the following arguments
spec:
  parallelism: 1
  arguments: --vus 1 --duration 1m --http-debug --out statsd
my script doesn’t contain any options and the default function only contains 2 requests, each with a 5 second sleep between them.
Taking all of this into consideration, my test should only complete 12 requests and 6 iterations however 6522 requests were sent… This only happens when using the k6 operator. Testing the same script locally works as expected
Hi @jokekpe,
Welcome to the forum! Could you please post your script and both outputs, with k6-operator and without it? Also, which command line do you use to run k6 without k6-operator?
Thanks.
Locally, without k6 operator
script:
import http from 'k6/http';
import { sleep, check } from 'k6';
let body;
let response;
let service_token;
export default function () {
  // our HTTP request, note that we are saving the response to res, which can be accessed later
  body = JSON.stringify(
      "email": "REDACTED",
      "token_duration": "short"
  response = http.post(
    'REDACTED',
    body,
        headers: {
            "Content-Type": "application/json",
            "Accept": "application/json",
  service_token = JSON.parse(response.body)["service_token"]
  sleep(5);
      "requests":[
            "request_id":"1",
            "action":"create",
            "resource":{
               "uri":"REDACTED",
               "scope":{
                  "organization":"REDACTED",
                  "billing_features":[
                     "user_groups"
    'REDACTED',
    body,
        headers: {
            "Authorization": `Bearer ${service_token}`
  sleep(5);
CLI command: k6 --vus 1 --duration 1m path/to/script.js
results
Locally in K8s w/ k6 operator
CRD:
apiVersion: k6.io/v1alpha1
kind: K6
metadata:
spec:
  parallelism: 1
  quiet: "false"
  script:
    configMap:
      # Remember...we created the 'test-scripts' ConfigMap with the available scripts inside.
      # Recreate the ConfigMag if you modify scripts or want additional scripts.
      # TODO - Want a different test script? Change it here.
      file: authorization.js
  • same script as above
  • same results
Looks like I’m only seeing the strange behavior when testing this while inside my orgs cluster…The k6-operator-controller-manager hasn’t been restarted in quite some time… I wonder if this might be the issue
Went scorched earth and re-applied the CRD and everything worked as expected… thanks for the help here!
