Hi all,
I am able  to run load test via k6 operator for smaller loads ie rps however when i try to run for larger rps and high number of parallelism i see failures in load test jobs with error
Job has reached the specified backoff limit
Here are the specs I am putting in my k6 operator :
 resources:
                limits:
                  cpu: 1000m
                  memory: 4096Mi
                requests:
                  cpu: 500m
                  memory: 1024Mi
and my load test scenarios :
export const options = {
  scenarios: {
    ramping_arrival_rate: {
      executor: 'ramping-arrival-rate',
      startRate: 20, // Start with 10 iterations/second
      timeUnit: '1s', // RPS will be calculated per second
      preAllocatedVUs: 10000, // Preallocate 50 VUs
      stages: [
        { target: 100, duration: '2m' },   // Ramp up to 500 RPS in 3 minutes
        { target: 1000, duration: '4m' },  // Ramp up to 1000 RPS in the next 2 minutes
        { target: 3000, duration: '3m' },  // Ramp up to 1500 RPS in the next 2 minutes
        { target: 0, duration: '1m' },     // Ramp down to 0 RPS over 2 minutes
i try to run these tests on 10 runners
I get the following response  when i try this command
**kubectl describe job load-test-3 -n argo**
Image:      578061096415.dkr.ecr.us-east-1.amazonaws.com/load-test:1.0.0
Port:       6565/TCP
Host Port:  0/TCP
Command:
k6
run
–quiet
–execution-segment=2/10:3/10
–execution-segment-sequence=0,1/10,2/10,3/10,4/10,5/10,6/10,7/10,8/10,9/10,1
–tag
testid=customer-exact-search-2024-10-23
/test/customer-exact-search.js
–address=0.0.0.0:6565
–paused
–tag
instance_id=3
–tag
job_name=load-test-3
Limits:
cpu:     1
memory:  4Gi
Requests:
cpu:      500m
memory:   1Gi
Liveness:   http-get http://:6565/v1/status delay=0s timeout=1s period=10s #success=1 #failure=3
Readiness:  http-get http://:6565/v1/status delay=0s timeout=1s period=10s #success=1 #failure=3
Environment:
DB_USERNAME:                  qqeq
DB_PASSWORD:                  qeqeq
DB_DATABASE:                  qqeqeq
DB_HOST:                      rrr
API_BASE_URL:                 api.mykaarma.com
TEST_DEALER_UUID:             a1dde11c73eca65b529b6125b98c0088dba81e7967f261e5601b0dc64e498ea4
TEST_DEPARTMENT_UUID:         ttt
SERVICE_SUSBCRIBER_USERNAME:  vhqU7KRiuEy1qfU4TEiYHP-E2zSJgz2CPKEedUPSCwo
SERVICE_SUSBCRIBER_PASSWORD:  k1_TunYv4vrgtGCGtc-CFqF99ER2Me8FbVOMwZlIY_M
TEST_DEALER_ID:               1
Mounts:
/test from k6-test-volume (rw)
/tmp from logfolder (rw)
Volumes:
k6-test-volume:
Type:      ConfigMap (a volume populated by a ConfigMap)
Optional:  false
logfolder:
Type:          HostPath (bare host directory volume)
Path:          /var/log/kaarya
HostPathType:
Events:
Type     Reason                Age    From            Message
Normal   SuccessfulCreate      3m11s  job-controller  Created pod: load-test-3-5q9h9
Warning  BackoffLimitExceeded  3m6s   job-controller  Job has reached the specified backoff limit
can any one tell me what could be possible reason ? also  one tihng i noticed is that i see an extra pod load-test-starter when everything works fine but not when the load-job- pods fails
