I am creating a Lightning web component that displays a list of records in a lightning-data table. After saving a new record to the database, the list is not updating. the code is here:
@wire(recordList, { recorded: '$recordId' })records(results) {
if (results.data) {
this.data = results.data;
} else if (results.error) {
this.showToast(results.error);
What should I need to change in the code above for creating a Lightning web component that displays a list of records in a lightning-data table? I also find the same question at this source: https://www.pass4future.com/questions/salesforce/pdii
but I am still unable to do this.
It looks like you're working with a Lightning Web Component (LWC) and are facing an issue where the data table is not updating after a DML operation. This is a common issue when the component does not automatically refresh to reflect changes in the underlying data. Here are a few suggestions to help you resolve this:
- Use
refreshApex
: After performing a DML operation, you can use the refreshApex
function to refresh the data in your component. This function forces a refresh of the data from the server. You need to import refreshApex
from @salesforce/apex
and call it after your DML operation.
```javascript
import { refreshApex } from '@salesforce/apex';
// After your DML operation
refreshApex(this.records);
Ensure Reactive Properties: Make sure that the properties you are using in your component are reactive. In your case, this.data
should be a reactive property. If it's not updating, ensure that it is declared as a reactive property using @track
(if you're using an older version of LWC) or simply as a class field (in newer versions).
Check for Errors: Ensure that there are no errors in your DML operation that might be preventing the data from being saved correctly. You can add error handling to your DML operation to catch and log any errors.
Verify Data Binding: Ensure that your data table is correctly bound to the this.data
property. If the data table is not bound correctly, it won't update when this.data
changes.
Debugging: Use console logs to debug and ensure that the results.data
is being updated correctly after the DML operation.
Here's a modified version of your code with refreshApex
import { LightningElement, wire } from 'lwc';
import recordList from '@salesforce/apex/YourApexClass.recordList';
export default class YourComponent extends LightningElement {
data;
wiredRecords;
records(results) {
this.wiredRecords = results;
if (results.data) {
handleDmlOperation() {
// Perform your DML operation here
// Refresh the data
refreshApex(this.wiredRecords);
showToast(error) {
// Implement your toast notification logic here
Make sure to replace YourApexClass
and recordList
with the actual names used in your project. This should help ensure that your data table updates correctly after a DML operation.
grot is still learning and improving, please let me know how I did by reacting below.
👍🏽 or 👎🏽
