I am developing a custom panel plugin, whereby the user can draw shapes on an embedded canvas.
A cut down example - but below illustrates that my component receives props, which contain a list of shapes.
export interface MyCustomOptions {
shapes: readonly Shape[];
export const MyCustomPanel: React.FC<PanelProps<MyCustomOptions>> = ({ props, data, eventBus, onOptionsChange }) => {
When a dashboard loads, I populate the canvas with any stored data, essentially as part of the React componentDidMount phase, and this works fine. My canvas exposes an onChange event callback, which I use to programatically mutate the component props with any changed/newly added shapes.
This is my bug scenario:
- User loads a dashboard with a panel already created, but a blank canvas. This mounts an instance of my ReactComponent - ‘A’.
- User clicks Edit Panel. This doesn’t un-mount the original component ‘A’, but does now create a second instance ‘B’ in addition.
- The user adds some new shapes to the components, which are set on the props.shapes field.
- The user clicks Save, persisting the props changes to the dashboard JSON.
- The user clicks the Grafana back arrow to return to the view mode. Unfortunately, the React component ‘A’ never received any updated copy of the props - so the canvas doesn’t reflect the changes just made in the edit view.
I’ve tried useEffect hooks, and polling the props in a setInterval loop - nothing seems to work barring refreshing the whole dashboard. Any help recommending how to keep the props state not stale between view/edit screens would be very welcome!
Best Regards,
Marcus
